path: root/configs/work_92105_defconfig
2017-08-11Convert CONFIG_CMD_MAX6957 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_MAX6957 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-05-22Convert CONFIG_CMD_HD44760 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_HD44760 Also drop CONFIG_CMD_HD44780 which appears to be a typo. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-13arm: lpc32xx: switch SPL builds to driver modelVladimir Zapolskiy
For NXP LPC32xx boards the change enables SPL_DM option, this allows to use any driver model UART driver in SPL images, hence a restriction on HSUART in SPL image is removed and well as definitions for non-DM NS16550 driver, its DM version is used instead. Because SPL_DM requires malloc(), enable CONFIG_SPL_SYS_MALLOC_SIMPLE for LPC32xx boards. The change adds about 5KB to the resulting SPL image (for devkit3250 board SPL image is increased from 10672 to 15608 bytes). Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-13arm: lpc32xx: switch serial console to driver modelVladimir Zapolskiy
On NXP LPC32xx platform for non-SPL builds the change adds standard (NS16550) and high-speed UARTs to driver model. Due to specific of DM NS16550 device description UART clock can not be got in runtime and by default it is set to 13MHz, if board PERIPH_CLK is different, this should be specified in board configuration file. For SPL builds HSUARTs are disabled and non-DM NS16550 driver is compiled, if needed. The change also updates default configs of devkit3250 and work_92105 boards to reflect updates in platform files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-10lpc32xx: add support for board work_92105Albert ARIBAUD \(3ADEV\)
Work_92105 from Work Microwave is an LPC3250- based board with the following features: - 64MB or 128MB SDR DRAM - 1 GB SLC NAND, managed through MLC controller. - Ethernet - Ethernet + PHY SMSC8710 - I2C: - EEPROM (24M01-compatible) - RTC (DS1374-compatible) - Temperature sensor (DS620) - DACs (2 x MAX518) - SPI (through SSP interface) - Port expander MAX6957 - LCD display (HD44780-compatible), controlled through the port expander and DACs This board has SPL support, and uses the LPC32XX boot image format. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
