path: root/configs/wb50n_defconfig
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-29board: laird: add WB50N CPU moduleBen Whitten
This board is based on the Atmel sama5d3 eval boards. Supporting the following features: - Boot from NAND Flash - Ethernet - FIT - SPL Signed-off-by: Ben Whitten <ben.whitten@lairdtech.com> Signed-off-by: Dan Kephart <dan.kephart@lairdtech.com>
