path: root/configs/warp_defconfig
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2018-10-22Kconfig: Convert CONFIG_IMX_WATCHDOG to KconfigXiaoliang Yang
Move this option to Kconfig and tidy up the config file of eight boards which use it. Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-29mx6sl: Select MX6SL option via KconfigBreno Lima
Currently the MX6SL option is selected via CONFIG_SYS_EXTRA_OPTIONS, but it is better to select it directly via Kconfig. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-07-12warp: Use PARTUUID to specify the rootfs locationFabio Estevam
warp can run different kernel versions, such as NXP 4.1 or mainline. Currently the rootfs location is passed via mmcblk number and the problem with this approach is that the mmcblk number for the eMMC changes depending on the kernel version. In order to avoid such issue, use UUID method to specify the rootfs location. Succesfully tested booting a NXP 4.1 and also a mainline 4.12 kernel. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-06warp: Fix RAM size runtime detectionFabio Estevam
Since commit a13d3757f7df ("warp: Use imx_ddr_size() for calculating the DDR size") warp board no longer boots. The reason for the breakage is that the warp board is using the DDR configuration from mx6slevk. A fundamental difference between warp and mx6slevk is that warp only uses one DDR chip select while mx6slevk uses two. The imx_ddr() function calculates the RAM size in runtime by reading the values of registers MDCTL and MDMISC. So in order to fix this warp boot issue, create a imximage DDR file specific to warp, where the MDCTL register is configured to only activates a single chip select. Reported-by: Breno Lima <breno.lima@nxp.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Breno Lima <breno.lima@nxp.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-02imx: mx6 move TARGET_xx Kconfig option to mx6 specific Kconfig filePeng Fan
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig. Add enable "CONFIG_ARCH_MX6" for boards based on mx6. Then we can choose target boards using "make ARCH=arm menuconfig" with ARCH_MX6 defined. If using original way, we have no chance to enable ARCH_MX6 when "make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig, kconfig will complains "arch/../configs/platinum_titanium_defconfig:3: warning: override: TARGET_PLATINUM_TITANIUM changes choice state" Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Eric Bénard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Marek Vasut <marex@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Soeren Moch <smoch@web.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Soeren Moch <smoch@web.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-02-23warp: Add initial WaRP Board supportOtavio Salvador
The WaRP Board is a Wearable Reference Plaform. The board features: - Freescale i.MX6 SoloLite processor with 512MB of RAM - Freescale FXOS8700CQ 6-axis Xtrinsic sensor - Freescale Kinetis KL16 MCU - Freescale Xtrinsic MMA955xL intelligent motion sensing platform The board implements a hybrid architecture to address the evolving needs of the wearables market. The platform consists of a main board and an example daughtercard with the ability to add additional daughtercards for different usage models. For more information about the project, visit: http://www.warpboard.org/ Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
