Prepare v2021.07-rc5
# gpg: Signature made Mon 28 Jun 2021 03:39:36 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# configs/am64x_evm_r5_defconfig
CONFIG_SYS_DFU_MAX_FILE_SIZE to Kconfig
Currently the config options CONFIG_SYS_DFU_DATA_BUF_SIZE and
CONFIG_SYS_DFU_MAX_FILE_SIZE are being set in include/configs/<board>.h
files and also in <board_name>_defconfig files without a Kconfig option. It
is easier for users to set these configs in defconfig files than in config
header files as they are a part of the source code.
Add Kconfig symbols, and update the defconfigs by using tools/moveconfig.py
script.
Suggested-by: Pratyush Yadav <p.yadav@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Acked-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Acked-by: Matthias Brugger <mbrugger@suse.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Done via moveconfig.py
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_MXC_UART
Acked-by: Peng Fan <peng.fan@nxp.com>
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2020.01
- imx8qxp_mek: increase buffer sizes and args number
- Fixes for imx7ulp
- imx8mm: Fix the first root clock in imx8mm_ahb_sels[]
- colibri_imx7: reserve DDR memory for Cortex-M4
- vining2000: fixes and convert to ethernet DM
- imx8m: fix rom version check to unbreak some B0 chips
- tbs2910: Disable VxWorks image booting support
U-Boot binary has grown in such a way that it goes beyond the reserved
area for the environment variables.
Running "saveenv" followed by a "reset" causes U-Boot to hang because
of this overlap.
Fix this problem by increasing the CONFIG_ENV_OFFSET size.
Also, in order to prevent this same problem in the future, use
CONFIG_BOARD_SIZE_LIMIT, which will detect the overlap in build-time.
CONFIG_BOARD_SIZE_LIMIT does not accept math expressions, so declare
CONFIG_ENV_OFFSET with its direct value instead.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Acked-by: Pierre-Jean Texier <pjtexier@koncepto.io>
Tested-by: Pierre-Jean Texier <pjtexier@koncepto.io>
Acked-by: Joris Offouga <offougajoris@gmail.com>
Tested-by: Joris Offouga <offougajoris@gmail.com>
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_SECURE_BOOT is too generic and forbids to use it for cross
architecture purposes. If Secure Boot is required for imx, this means to
enable and use the HAB processor in the soc.
CONFIG_FSL_USDHC
[trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list]
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Porting to DM and i.MX8
- warp7 to DM
- kp_imx53 to DM
- Warnings in DT
- MX8QM support
- colibri-imx6ull to DM
- imx7d-pico to DM
- ocotp for MX8
This commit switches to DM USB for warp7 and warp7_bl33 defconfigs.
Signed-off-by: Pierre-Jean Texier <pjtexier@koncepto.io>
Signed-off-by: Joris Offouga <offougajoris@gmail.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
This commit switches to DM SERIAL for warp7 and warp7_bl33 defconfigs.
This patch converts the warp7 and warp7_bl33 board ports over to using the
DM PMIC model.
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
This commit switches to DM I2C for warp7 and warp7_bl33 defconfigs.
Switches on the IMX7 pinctrl driver for the warp7 and warp7_bl33 ports,
necessary to convert over to DM for this board.
It is necessary to switch on pinctrl and GPIO in one go.
Converts from fixed initialization of MMC to DM initialization of MMC.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
This patch adds DT file hooks for imx7s-warp.dtb to the warp7 and
warp7_bl33 builds.
The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
This enable FIT image support.
We may have, the not yet considered, scenario where OPTEE is loaded before
u-boot and *not* by u-boot, e.g, the boot flow using the ARM Trusted
Firmware (ATF), where in the 32bit flow is:
BootRom->ATF(BL2)->Optee(BL32)->u-boot(BL33)
In this case we need still to reserve the memory used by optee, to avoid
for example to realocate ourself to the same address at the end of DRAM.
So, we change here the dependencies on the OPTEE lib and we set the default
size and base of TZRAM to zero.
Signed-off-by: Rui Miguel Silva <rui.silva@linaro.org>
Cc: Ryan Harkin <ryan.harkin@linaro.org>
Cc: u-boot@lists.denx.de
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Booting the following image with tip-of-tree we get a CAAM DECO error (and
subsequent crash due to a kernel bug in 4.1).
http://freescale.github.io/#download -> BoardsWaRPboard community - WaRP -
Wearable Reference PlatformFSL Community BSP 2.3fsl-image-multimediawayland
Image: fsl-image-multimedia-imx7s-warp-20180323-90.rootfs.sdcard
Error:
caam 30900000.caam: Entropy delay = 3200
caam 30900000.caam: failed to acquire DECO 0
<snip>
caam 30900000.caam: Entropy delay = 12400
caam 30900000.caam: failed to instantiate RNG
WARNING: CPU: 0 PID: 1 at
/home/jenkins/workspace/fsl-community-bsp-pyro_xwayland_2/build/tmp/work-shared/imx7s-warp/kernel-source/mm/vmalloc.c:1465
caam_remove+0x6)
Trying to vfree() nonexistent vm area (88047000)
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted
4.1.36-4.1-1.0.x-imx-warp7+ga543d1b #1
Hardware name: Freescale i.MX7 Dual (Device Tree)
[<80015d54>] (unwind_backtrace) from [<80012688>] (show_stack+0x10/0x14)
[<80012688>] (show_stack) from [<8076e810>] (dump_stack+0x78/0x8c)
[<8076e810>] (dump_stack) from [<800346a0>]
(warn_slowpath_common+0x80/0xb0)
[<800346a0>] (warn_slowpath_common) from [<80034700>]
(warn_slowpath_fmt+0x30/0x40)
[<80034700>] (warn_slowpath_fmt) from [<8054c278>] (caam_remove+0x6c/0x3f4)
[<8054c278>] (caam_remove) from [<8054ce74>] (caam_probe+0x874/0xfa8)
[<8054ce74>] (caam_probe) from [<80382a7c>] (platform_drv_probe+0x48/0xa4)
[<80382a7c>] (platform_drv_probe) from [<80381328>]
(driver_probe_device+0x174/0x2a8)
[<80381328>] (driver_probe_device) from [<8038152c>]
(__driver_attach+0x8c/0x90)
[<8038152c>] (__driver_attach) from [<8037f9d4>]
(bus_for_each_dev+0x68/0x9c)
[<8037f9d4>] (bus_for_each_dev) from [<80380a68>]
(bus_add_driver+0xf4/0x1e8)
[<80380a68>] (bus_add_driver) from [<80381b38>] (driver_register+0x78/0xf4)
[<80381b38>] (driver_register) from [<80009738>]
(do_one_initcall+0x8c/0x1d0)
[<80009738>] (do_one_initcall) from [<80a66dac>]
(kernel_init_freeable+0x140/0x1d0)
[<80a66dac>] (kernel_init_freeable) from [<8076aa38>]
(kernel_init+0x8/0xe8)
[<8076aa38>] (kernel_init) from [<8000f468>] (ret_from_fork+0x14/0x2c)
---[ end trace d5f941204ed8cb28 ]---
caam: probe of 30900000.caam failed with error -11
Unable to handle kernel NULL pointer dereference at virtual address
00000004
pgd = 80004000
[00000004] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT SMP ARM
<snip>
[<8055cdf8>] (caam_sm_startup) from [<80aa83c8>] (caam_sm_init+0x50/0x58)
[<80aa83c8>] (caam_sm_init) from [<80009738>] (do_one_initcall+0x8c/0x1d0)
Code: e59d300c e2832010 e5843008 e5834068 (e58a2004)
---[ end trace d5f941204ed8cb29 ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
Fix: Enable the CAAM correctly by setting CONFIG_ARMV7_BOOT_SEC_DEFAULT=y
in the upstream defconfig.
Cc: Breno Lima <breno.lima@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Breno Lima <breno.lima@nxp.com>
setexpr allows us to do arithmetic for env variables - something that is
both useful and required when doing HAB authentication without hard-coding
HAB load addresses.
This patch enables CMD_SETEXPR for the WaRP7 defconfig.
This patch enables CONFIG_BOOTM_TEE. Once enabled its possible to
chain-load Linux through OPTEE.
Loading kernel to 0x80800000
=> run loadimage
Load FDT to 0x83000000
=> run loadfdt
Load OPTEE to 0x84000000
=> fatload mmc 0:5 0x84000000 /lib/firmware/uTee.optee
Then chain-load to the kernel via OPTEE
=> bootm 0x84000000 - 0x83000000
Image Name:
Image Type: ARM Trusted Execution Environment Kernel Image (uncompressed)
Data Size: 249844 Bytes = 244 KiB
Load Address: 9dffffe4
Entry Point: 9e000000
Verifying Checksum ... OK
Loading Kernel Image ... OK
Various function associated with booting the WaRP7 in High Assurance Boot
(HAB) mode are enabled by switching on CONFIG_SECURE_BOOT.
This patch enables CONFIG_SECURE_BOOT for the WaRP7 defconfig.
In order to sign images with the IMX code-signing-tool (CST) we need to
know the load address of a given image. The best way to derive this load
address is to make it into a define - so that u-boot.cfg contains the
address - which we can then parse when generating the IMX CST headers.
This patch makes the OPTEE_LOAD_ADDR available via u-boot.cfg for further
parsing by external tools.
Reviewed-by: Ryan Harkin <ryan.harkin@linaro.org>
Requires setting CONFIG_OPTEE=y and setting an OPTEE TrustZone DRAM base in
include/configs/warp7.h.
This enable generic file system commands (load, ls).
Signed-off-by: Pierre-Jean TEXIER <texier.pj2@gmail.com>
Acked-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
