The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
This commit enables SYSRESET in the defconfigs for the
Atmel/Microchip platforms.
Signed-off-by: Sergiu Moga <sergiu.moga@microchip.com>
The most commonly used value today is 0x2000 and not 0x400. Rework the
Kconfig logic to use this more frequently used value as the default.
Cc: Andrew F. Davis <afd@ti.com>
Cc: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
Cc: Andes <uboot@andestech.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bharat Gooty <bharat.gooty@broadcom.com>
Cc: David Lechner <david@lechnology.com>
Cc: Dzmitry Sankouski <dsankouski@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Eugeniy Paltsev <paltsev@synopsys.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Gerald Kerma <dreagle@doukki.net>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
Cc: Holger Brunck <holger.brunck@hitachienergy.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Kristian Amlie <kristian.amlie@northern.tech>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Liviu Dudau <liviu.dudau@foss.arm.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Cc: Matthias Brugger <mbrugger@suse.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Cc: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Cc: Stefan Bosch <stefan_b@posteo.net>
Cc: Stephan Gerhold <stephan@gerhold.net>
Cc: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Thomas Weber <weber@corscience.de>
Cc: Tony Dinh <mibodhi@gmail.com>
Cc: Trevor Woerner <twoerner@gmail.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: liuhao <liuhao@phytium.com.cn>
Cc: lixinde <lixinde@phytium.com.cn>
Cc: shuyiqi <shuyiqi@phytium.com.cn>
Cc: weichangzheng <weichangzheng@phytium.com.cn>
Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Reviewed-by: Tony Dinh <mibodhi@gmail.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Kristian Amlie <kristian.amlie@northern.tech>
CONFIG_RMII
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_NET_RETRY_COUNT
CONFIG_BOOTP_MAY_FAIL
CONFIG_BOOTP_VENDOREX
CONFIG_BOOTP_BOOTFILESIZE
CONFIG_BOOTP_NISDOMAIN
CONFIG_BOOTP_TIMEOFFSET
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_MACB
Resync all defconfig files using moveconfig.py
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
As this platform already enables CONFIG_DM and CONFIG_OF_CONTROL,
migrating to DM_USB and DM_SPI_FLASH is just a matter of enabling the
correct options.
u-boot@lists.denx.de (open list)
Reported-by: Marek Behun <marek.behun@nic.cz>
CONFIG_ATMEL_USART
CONFIG_AT91_GPIO
- Finish migration of CONFIG_PHYLIB and a number of related symbols to
defconfig files.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
CONFIG_SF_DEFAULT_MODE
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Sync DTS from Linux and add FDT support for AT91 vinco board.
usb0, usb1, and usb2 nodes removed, since there is no support it.
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The usb_ether gadget duplicates the USB settings for the manufacturer,
product ID and vendor ID.
Make sure we use the common option so that we can expect a single VID/PID
couple for a single device.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The USB Ethernet gadget option has not yet been moved to Kconfig, let's
deal with that.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option,
which is deprecated, use the CONFIG_XXXX_BOOT options to
indicate the boot media, and the SoC is selected by the board.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
