path: root/configs/vf610twr_defconfig
2017-10-04printk: collect printk stuff into <linux/printk.h> with loglevel supportMasahiro Yamada
When we import code from Linux, with regular re-sync planned, we want to use printk() and pr_*(). U-Boot does not support them in a clean way. So, people end up with local macros, or compat headers here and there, then we occasionally see build errors of definition conflicts. We have include/linux/compat.h, but putting all sorts of unrelated things into a single header is just a temporal workaround. Hence this patch, to find the best home for all printk variants. If you want to use printk() and friends, please include <linux/printk.h>. This header is self-contained, and pulls in only a few headers. When I was testing this clean-up, I noticed the image size exceeded its platform limit on some boards. This is because all pr_*() that were previously defined as no-op in include/linux/mtd/mtd.h (unless CONFIG_MTD_DEBUG is set), are now enabled. To make such boards happy, this commit also implements CONFIG_LOGLEVEL. The concept is similar to the kernel parameter "loglevel". (Actually, the Kconfig help message was taken from kernel-paremeter.txt of Linux) Messages with a loglevel smaller than console loglevel will be printed. The difference is the loglevel is build-time determined. To save the image size, lower priority pr_*() are compiled out. I set the default of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages are compiled in. I adjusted CONFIG_LOGLEVEL to avoid build error for some boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> [trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-05-22Convert CONFIG_CMD_FUSE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FUSE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-19ARM: vf610: move to standard arch/board approachStefan Agner
Move Freescale/NXP Vybrid to a standard arch/board approach, similar to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM: mx6: move to a standard arch/board approach"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-02arm: vybrid: Update defconfig'sBhuvanchandra DV
Let's go with pure DT solution for board's based on NXP/Freescale Vybrid platform. - Merge the DT defconfig with non-DT defconfig for Toradex Colibri VF50/VF61 and drop the non-DT defconfig. - Update the legacy defconfigs for NXP/Freescale VF610 Tower Board with DT. - Update the legacy defconfigs for Phytec phyCORE-vybrid Board with DT. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-20serial: lpuart: Move CONFIG_FSL_LPUART to KconfigBin Meng
LPUART is seen on Freescale VF610 and QorIQ Layerscape devices. Create a Kconfig option and move it to defconfig for all boards that have this serial driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-24mtd: vf610_nfc: add Freescale NFC controller configs to KconfigStefan Agner
This commit allows users to enable/disable the Freescale NFC controller found in systems like Vybrid (VF610), MPC5125, MCF54418 or Kinetis K70 via Kconfig with more detailed help docs. Signed-off-by: Stefan Agner <stefan@agner.ch> Acked-by: Stefano Babic <sbabic@denx.de> [scottwood: updated vf610twr_nand_defconfig] Signed-off-by: Scott Wood <scottwood@freescale.com>
2014-09-16arm: vf610: add NAND support for vf610twrStefan Agner
This adds NAND support for the Vybrid tower system (TWR-VF65GS10) provided by the vf610_nfc driver. Full 16-Bit bus width is supported. Also an aditional config vf610twr_nand is introduced which gets the environment from NAND. However, booting U-Boot from NAND is not yet possible due to missing boot configuration block (BCB). Signed-off-by: Stefan Agner <stefan@agner.ch>
