path: root/configs/vf610twr_defconfig
2017-05-22Convert CONFIG_CMD_FUSE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FUSE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-19ARM: vf610: move to standard arch/board approachStefan Agner
Move Freescale/NXP Vybrid to a standard arch/board approach, similar to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM: mx6: move to a standard arch/board approach"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-02arm: vybrid: Update defconfig'sBhuvanchandra DV
Let's go with pure DT solution for board's based on NXP/Freescale Vybrid platform. - Merge the DT defconfig with non-DT defconfig for Toradex Colibri VF50/VF61 and drop the non-DT defconfig. - Update the legacy defconfigs for NXP/Freescale VF610 Tower Board with DT. - Update the legacy defconfigs for Phytec phyCORE-vybrid Board with DT. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-20serial: lpuart: Move CONFIG_FSL_LPUART to KconfigBin Meng
LPUART is seen on Freescale VF610 and QorIQ Layerscape devices. Create a Kconfig option and move it to defconfig for all boards that have this serial driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-24mtd: vf610_nfc: add Freescale NFC controller configs to KconfigStefan Agner
This commit allows users to enable/disable the Freescale NFC controller found in systems like Vybrid (VF610), MPC5125, MCF54418 or Kinetis K70 via Kconfig with more detailed help docs. Signed-off-by: Stefan Agner <stefan@agner.ch> Acked-by: Stefano Babic <sbabic@denx.de> [scottwood: updated vf610twr_nand_defconfig] Signed-off-by: Scott Wood <scottwood@freescale.com>
2014-09-16arm: vf610: add NAND support for vf610twrStefan Agner
This adds NAND support for the Vybrid tower system (TWR-VF65GS10) provided by the vf610_nfc driver. Full 16-Bit bus width is supported. Also an aditional config vf610twr_nand is introduced which gets the environment from NAND. However, booting U-Boot from NAND is not yet possible due to missing boot configuration block (BCB). Signed-off-by: Stefan Agner <stefan@agner.ch>
