Use moveconfig.py script to convert define CONFIG_SYS_MAX_FLASH_BANKS
and CONFIG_SYS_MAX_FLASH_BANKS_DETECT to Kconfig and move these entries
to defconfigs.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
[trini: Re-switch to IS_ENABLED check in spi-nor-core.c, re-run migration]
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
- Add missing CONFIG_SYS_LOAD_ADDR based on other platforms
- Resync
vexpress_ca9x4 is seemingly the only board except for qemu_arm which
is able to run U-Boot correctly, using the `-M vexpress-a9` option to
QEMU. Building for qemu_arm and running qemu-system-arm with the `-M
virt` argument has a number of downsides, most importantly that it
only supports virtio storage drivers. This significantly reduces its
usefulness in testing memory card and Flash solutions, especially when
the tested images are from a third party source.
So therefore we reintroduce the vexpress_ca9x4 board in this commit,
with the explicit goal of using it with QEMU.
A number of differences to note from the original:
* Since the board was apparently unmaintained, I have now set myself
as the maintainer.
* The board has been converted to use the driver model, which was the
reason it was removed in the first place.
* The vexpress_ca15_tc2 and vexpress_ca5x2 boards, which were removed
in the same commit, are not necessary for the QEMU use case, and
have been omitted.
* An `mmc0` alias was introduced in the dts file. The mmc is not
detected correctly without this, now that it's based on the device
tree instead of the board's init function.
* A couple of other nodes were removed because they were problematic
when trying to run the UEFI bootmgr. Once again, the primary use
case here is QEMU, and these nodes are not needed for that to work.
* Unnecessary board init code has been removed, thanks to driver model
and device tree.
* `CONFIG_OF_EMBED` has been enabled. I know this goes against
recommended practice, but there doesn't seem to be any other way to
pass the dtb to U-Boot in the QEMU scenario. Using the -dtb argument
does not work, I suppose because U-Boot doesn't use the same
mechanics as the kernel when it's booting.
* Load addresses have been changed to fit QEMU use case.
People wanting to get a more detailed, yet somewhat isolated, diff
between this and the original, can run this command:
git diff c6c26a05b89f25a06e7562f8c2071b60fd0c9eac~1 -- \
$( git diff-tree --diff-filter=A -r --name-only HEAD~1 HEAD)
(Make sure to either check out this commit first, or replace HEAD with
the commit ID of this commit)
Signed-off-by: Kristian Amlie <kristian.amlie@northern.tech>
This board has not been converted to CONFIG_DM_MMC by the deadline.
Remove it.
Cc: Linus Walleij <linus.walleij@linaro.org>
The "cmd/Kconfig" has a TODO description for CMD_MISC that it should
really be named as CMD_SLEEP. Change it in the whole source tree.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_ARM_PL180_MMCI
EFI was disabled in f95b8a4b5f64f because of the missing DTB file,
and indeed, the DTB file is required to load recent versions of GRUB
(2.04) correctly.
Currently this causes failures of the platform when running the EFI
loader tests, so disable it for now.
This reverts commit af827140e5965e5bb2bcad1c53ca8419b428ff6d.
(2.04) correctly.
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
vexpress_ca15_tc2_defconfig and vexpress_ca9x4_defconfig do not provide
device trees (as $fdtcontroladdr) as needed to pass our Travis CI tests.
As we are on the move to requiring block devices to be based on the driver
model these boards either will have to be converted to use device trees or
will be kicked out of U-Boot.
So let's disable CONFIG_EFI_LOADER on these boards until the device tree
issue is resolved.
This allow for convenient use of QEMU machine to test loading of UBI
filesystem. There are a couple of changes made together of this which
are required:
1) The malloc must be at least 512 KiB to allow the use of UBI
filesystem. We are going to enable it in a next patch.
2) MTD_DEVICE must be enabled, otherwise we get missing symbols
during the build
Following configs were change:
- vexpress_aemv8a_dram_defconfig
- vexpress_aemv8a_juno_defconfig
- vexpress_aemv8a_semi_defconfig
- vexpress_ca15_tc2_defconfig
- vexpress_ca5x2_defconfig
- vexpress_ca9x4_defconfig
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Liviu Dudau <liviu.dudau@arm.com>
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
[trini: Re-migrate]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
We first introduce CONFIG_USE_BOOTCOMMAND, similar to
CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most
CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex
scheme around this usage, and these have been defered for the moment so
that platform maintainers can work on a migration plan.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
We add the various SMC91XX symbols to drivers/net/Kconfig and then this
CONFIG_SMC911X
CONFIG_SMC911X_BASE
CONFIG_SMC911X_16_BIT
CONFIG_SMC911X_32_BIT
[trini: Apply to the rest of the tree, re-squash old and new patch]
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
CONFIG_ENV_IS_IN_FLASH
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
A number of platforms had been using the distro default feature before
it was moved to Kconfig but did not enable the new Kconfig option when
it was enabled. This caused a regression in terms of features and this
introduces breakage when more things move to Kconfig.
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
We have a bunch of boards that define their vendor class identifier and
client archs in the board files or in the distro config. Move everything
to the generic Kconfig options.
We're missing the distinction between i386 and x86_64, as I couldn't find
any config variable that would tell us the difference. Is that really important
to people? I guess not, so I left it out.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
