CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
CONFIG_SYS_MAXARGS
Set CONFIG_COUNTER_FREQUENCY according to COUNTER_FREQUENCY in
config header file.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
[trini: Re-run migration]
The ARMv8-R64 architecture introduces optional VMSA (paging based MMU)
support in the EL1/0 translation regime, which makes that part mostly
compatible to ARMv8-A.
Add a new board variant to describe the "BASE-R64" FVP model, which
inherits a lot from the existing v8-A FVP support. One major difference
is that the memory map in "inverted": DRAM starts at 0x0, MMIO is at
2GB [1].
* Create new TARGET_VEXPRESS64_BASER_FVP target, sharing most of the
exising configuration.
* Implement inverted memory map in vexpress_aemv8.h
* Create vexpress_aemv8r defconfig
* Provide an MMU memory map for the BASER_FVP
* Update vexpress64 documentation
At the moment the boot-wrapper is the only supported secure firmware. As
there is no official DT for the board yet, we rely on it being supplied
by the boot-wrapper into U-Boot, so use OF_HAS_PRIOR_STAGE, and go with
a dummy DT for now.
[1] https://developer.arm.com/documentation/100964/1114/Base-Platform/Base---memory/BaseR-Platform-memory-map
Signed-off-by: Peter Hoyes <Peter.Hoyes@arm.com>
[Andre: rebase and add Linux kernel header]
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
[trini: Add MAINTAINERS entry for Peter]
