path: root/configs/vexpress_aemv8a_juno_defconfig
2017-02-08cmd: move CONFIG_CMD_UNZIP and CONFIG_CMD_ZIP to KconfigMasahiro Yamada
CONFIG_CMD_ZIP is not defined by any board. I am moving CONFIG_CMD_UNZIP to defconfig files except UniPhier SoC family. I am the maintainer of UniPhier platform, so I know "select CMD_UNZIP" is better for this platform. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-27net: Move the VCI and client arch values to KconfigAlexander Graf
We have a bunch of boards that define their vendor class identifier and client archs in the board files or in the distro config. Move everything to the generic Kconfig options. We're missing the distinction between i386 and x86_64, as I couldn't find any config variable that would tell us the difference. Is that really important to people? I guess not, so I left it out. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-01-30vexpress64: support the Juno Development PlatformLinus Walleij
The Juno Development Platform is a physical Versatile Express device with some differences from the emulated semihosting models. The main difference is that the system is split in a SoC and an FPGA where the SoC hosts the serial ports at totally different adresses. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
