path: root/configs/ventana_defconfig
2022-06-06Convert CONFIG_SYS_SPL_MALLOC_SIZE et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_SPL_MALLOC_START We introduce a default value here as well, and CONFIG_SYS_SPL_MALLOC to control if we have a malloc pool or not. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SPL_STACK to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_STACK Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SPL_BSS_MAX_SIZE et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_BSS_MAX_SIZE CONFIG_SPL_MAX_FOOTPRINT Note that the da850evm platforms were violating the "only use one" rule here, and so now hard-code their BSS limit. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SYS_PBSIZE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_PBSIZE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SYS_MAXARGS to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MAXARGS Signed-off-by: Tom Rini <trini@konsulko.com>
2021-12-27Convert CONFIG_CONS_INDEX et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX CONFIG_DEBUG_UART_CLOCK CONFIG_FSL_TZPC_BP147 CONFIG_GENERIC_ATMEL_MCI CONFIG_IDENT_STRING CONFIG_LIBATA CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE CONFIG_LPC32XX_GPIO CONFIG_MP CONFIG_MPC8XXX_GPIO CONFIG_MTD_PARTITIONS CONFIG_MVGBE CONFIG_MXC_GPIO CONFIG_NR_DRAM_BANKS CONFIG_OF_BOARD_SETUP CONFIG_OF_STDOUT_VIA_ALIAS CONFIG_OF_SYSTEM_SETUP CONFIG_PREBOOT CONFIG_ROCKCHIP_SERIAL CONFIG_RTC_ENABLE_32KHZ_OUTPUT CONFIG_RTC_MV CONFIG_SCSI_AHCI CONFIG_SF_DEFAULT_BUS CONFIG_SF_DEFAULT_CS CONFIG_SF_DEFAULT_SPEED CONFIG_SOFT_SPI CONFIG_SPI_FLASH_EON CONFIG_SPI_FLASH_MACRONIX CONFIG_SPI_FLASH_MTD CONFIG_SPI_FLASH_SPANSION CONFIG_SPI_FLASH_SST CONFIG_SPI_FLASH_STMICRO CONFIG_SUPPORT_RAW_INITRD CONFIG_SYS_ARCH_TIMER CONFIG_SYS_BOARD CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_DCACHE_OFF CONFIG_SYS_FDT_SAVE_ADDRESS CONFIG_SYS_FLASH_CFI CONFIG_SYS_FSL_ERRATUM_ESDHC135 CONFIG_SYS_HAS_SERDES CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_LITTLE_ENDIAN CONFIG_SYS_LOAD_ADDR CONFIG_SYS_MMCSD_FS_BOOT_PARTITION CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR CONFIG_SYS_NS16550 CONFIG_SYS_PLLFIN CONFIG_SYS_SPI_U_BOOT_OFFS CONFIG_TIMER_SYS_TICK_CH CONFIG_USB_EHCI_FSL CONFIG_U_QE CONFIG_VERSION_VARIABLE Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-31Convert CONFIG_SYS_LOAD_ADDR to KconfigTom Rini
Now that we have consistent usage, migrate this symbol to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2021-07-26configs: Resync with savedefconfigTom Rini
2021-06-28configs: Resync with savedefconfigTom Rini
2020-08-10configs: Resync with savedefconfigTom Rini
2020-08-08Convert CONFIG_SYS_MMC_ENV_DEV et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MMC_ENV_DEV CONFIG_SYS_MMC_ENV_PART Note that with this conversion we now have consistent behavior with respect to ensuring that we have always selected the correct MMC device and hardware partition. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-08-04arm: move CONFIG_PREBOOT="usb start" to KConfigJonas Smedegaard
This commit moves CONFIG_PREBOOT="usb start" to common/KConfig for all boards also declaring USB_KEYBOARD. Besides simplifying defconfig files, this also enables support for board-specific CONFIG_PREBOOT for sunxi boards: commit 37304aaf60bf ("Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to Kconfig") intended to support CONFIG_PREBOOT, but include/configs/sunxi-common.h hardcodes preboot as part of internally defined CONSOLE_STDIN_SETTINGS, silently ignoring any board-specific CONFIG_PREBOOT. Signed-off-by: Jonas Smedegaard <dr@jones.dk> Reviewed-by: Neil Armstrong <narmstrong@baylibre.com> Series-Cc: Jagan Teki <jagan@amarulasolutions.com> Series-Cc: Lukasz Majewski <lukma@denx.de> Series-Cc: Andre Przywara <andre.przywara@arm.com>
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-15rename symbol: CONFIG_TEGRA -> CONFIG_ARCH_TEGRATrevor Woerner
Have this symbol follow the pattern of all other such symbols. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-02-06video: enable VIDEO_ANSI and all VIDEO_BBP optionsAnatolij Gustschin
This partially reverts changes by commit 2cc393f32fd9 ("video: make BPP and ANSI configs optional") since it caused issues with other boards (missing LCD console output on pinebook, x86 platform or sandbox). Enable all disabled options again and opt out of not supported color depth in board defconfigs. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Vagrant Cascadian <vagrant@debian.org>
2019-12-06video: make BPP and ANSI configs optionalAnatolij Gustschin
Many boards do not use all selected framebuffer depth configurations, for such boards there is some unused code in video and console uclass routines. Make depth specific code optional to avoid dead code and slightly reduce binary size. Also make ANSI code optional for the same reason. When i.e. using only VIDEO_BPP16 the code size shrinks (below values when using gcc-7.3.0): $ ./tools/buildman/buildman -b video-wip -sS wandboard ... 01: Merge git://git.denx.de/u-boot-sh 02: video: add guards around 16bpp/32bbp code 03: video: make BPP and ANSI configs optional arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0 Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Eugen Hristev <eugen.hristev@microchip.com> Tested-by: Patrice Chotard <patrice.chotard@st.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-02-20Kconfig: tegra: Migrate USB_EHCI_TEGRAPeter Robinson
Migrate USB_EHCI_TEGRA from headers to Kconfig Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Marek Vasut <marex@denx.de> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Peter.Chubb@data61.csiro.au Cc: Lucas Stach <dev@lynxeye.de> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-27usb: kbd: Set a default polling mechanism for USB keyboardBin Meng
The choice of "USB keyboard polling" cannot be optional as without one mechanism being set, it just doesn't work. Set the default one to CONFIG_SYS_USB_EVENT_POLL. Fixes: ecad7051 ("configs: Migrate all of the existing USB symbols, except fastboot") Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-01tegra: Convert MMC to use driver model for operationsSimon Glass
Enable CONFIG_DM_MMC_OPS and CONFIG_BLK for all Tegra devices. This moves Tegra to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
