path: root/configs/vct_premium_onenand_defconfig
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-20net: Add SMC911X driver to Kconfig, convertAdam Ford
We add the various SMC91XX symbols to drivers/net/Kconfig and then this converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_16_BIT CONFIG_SMC911X_32_BIT Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Apply to the rest of the tree, re-squash old and new patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_ONENAND to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ONENAND Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-25Convert CONFIG_ENV_IS_IN_ONENAND to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_ONENAND Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2014-11-01MIPS: kconfig: add options for vct board variant selectDaniel Schwierzeck
The vct board can be built with various variants which are configured via CONFIG_SYS_EXTRA_OPTIONS. This is deprecated. Thus add new Kconfig options for those board variants. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2014-11-01MIPS: kconfig: add options for endianess selectDaniel Schwierzeck
Add new Kconfig option to let the user select the targets endianess. Each target have to select SUPPORTS_BIG_ENDIAN and/or SUPPORTS_LITTLE_ENDIAN to indicate which endianess is supported. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
