path: root/configs/vct_platinumavc_small_defconfig
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-01MIPS: kconfig: add options for vct board variant selectDaniel Schwierzeck
The vct board can be built with various variants which are configured via CONFIG_SYS_EXTRA_OPTIONS. This is deprecated. Thus add new Kconfig options for those board variants. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2014-11-01MIPS: kconfig: add options for endianess selectDaniel Schwierzeck
Add new Kconfig option to let the user select the targets endianess. Each target have to select SUPPORTS_BIG_ENDIAN and/or SUPPORTS_LITTLE_ENDIAN to indicate which endianess is supported. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-09-24kconfig: move CONFIG_CMD_CRC32 to KconfigMasahiro Yamada
Since CONFIG_CMD_CRC32 is defined in config_cmd_defaults.h, it is enabled for all the boards except the ones undefining it explicitly: kwb tseries_mmc tseries_nand tseries_spi vct_platinum_onenand_small vct_platinum_small vct_platinumavc_onenand_small vct_platinumavc_small vct_premium_onenand_small vct_premium_small The default value of this config option should be "y" and "# CONFIG_CMD_CRC32 is not set" should be added for those exceptions. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
