path: root/configs/vct_platinumavc_defconfig
2014-11-01MIPS: kconfig: add options for vct board variant selectDaniel Schwierzeck
The vct board can be built with various variants which are configured via CONFIG_SYS_EXTRA_OPTIONS. This is deprecated. Thus add new Kconfig options for those board variants. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2014-11-01MIPS: kconfig: add options for endianess selectDaniel Schwierzeck
Add new Kconfig option to let the user select the targets endianess. Each target have to select SUPPORTS_BIG_ENDIAN and/or SUPPORTS_LITTLE_ENDIAN to indicate which endianess is supported. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
