CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
CONFIG_SYS_I2C_MXC
CONFIG_SYS_I2C_MXC_I2C1
CONFIG_SYS_I2C_MXC_I2C2
CONFIG_SYS_I2C_MXC_I2C3
CONFIG_SYS_I2C_MXC_I2C4
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
Convert usbarmory to OF_CONTROL and DM for gpio, pin
usb support on the i.MX53 based usbarmory.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Cc: Andrej Rosano <andrej@inversepath.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
CONFIG_MXC_UART
Acked-by: Peng Fan <peng.fan@nxp.com>
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
Porting to DM and i.MX8
- warp7 to DM
- kp_imx53 to DM
- Warnings in DT
- MX8QM support
- colibri-imx6ull to DM
- imx7d-pico to DM
- ocotp for MX8
CONFIG_USB_EHCI_MX5
Signed-off-by: Lukasz Majewski <lukma@denx.de>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
We first introduce CONFIG_USE_BOOTCOMMAND, similar to
CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most
CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex
scheme around this usage, and these have been defered for the moment so
that platform maintainers can work on a migration plan.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_CMD_FUSE
CONFIG_CMD_BMODE
[trini: Make this default y and depend on mx5/6/7]
A number of platforms had been using the distro default feature before
it was moved to Kconfig but did not enable the new Kconfig option when
it was enabled. This caused a regression in terms of features and this
introduces breakage when more things move to Kconfig.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Add support for Inverse Path USB armory board, an open source
flash-drive sized computer based on Freescale i.MX53 SoC.
http://inversepath.com/usbarmory
Signed-off-by: Andrej Rosano <andrej@inversepath.com>
Cc: Chris Kuethe <chris.kuethe@gmail.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Vagrant Cascadian <vagrant@debian.org>
Tested-By: Vagrant Cascadian <vagrant@debian.org>
Tested-by: Chris Kuethe <chris.kuethe@gmail.com>
