path: root/configs/uniphier_v7_defconfig
2019-09-23configs: Resync with savedefconfigTom Rini
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-02-22preboot: Introduce CONFIG_USE_PREBOOT and migrate CONFIG_PREBOOTMasahiro Yamada
This is the same migration path as commit b6251db8c3f0 ("Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMAND"). I also moved the description in README to the Kconfig help. I ripped off the sentence about 'LWMON' since it is gone already. I only let my boards migrate, leaving the rest to platform maintainers. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-29ARM: uniphier: allow to source boot script before distro-bootMasahiro Yamada
Some users might need additional setups before booting the kernel. If there is found a file 'boot.scr', run it before invoking the distro boot command. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-12-29ARM: uniphier: do not modify bootcmd environment variable at run-timeMasahiro Yamada
Some users might want to modify 'bootcmd' at compile-time by editing include/configs/uniphier.h, but overwriting it at run-time makes it impossible. Instead, set 'bootdev' at run-time, which contains the boot device the system is booting from, then indirectly reference it from 'bootcmd'. It is up to users whether to override 'bootcmd'. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-11ARM: uniphier: enable CONFIG_CMD_UBIMasahiro Yamada
Now that CONFIG_SYS_MONITOR_LEN increased, we have room for enabling more options again. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-07-25ARM: uniphier: enable MTD partition and UBIMasahiro Yamada
Enable "mtdparts" and "ubi" commands for uniphier_v8_defconfig to use UBI on NAND devices. Enable only "mtdparts" for uniphier_{v7,ld4_sld8}_defconfig because enabling UBI would increase 170KB, which would be memory footprint problem. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-06-23ARM: uniphier: enable CONFIG_SNI_AVE and disable CONFIG_SMC911XMasahiro Yamada
Enable the on-chip ethernet driver for uniphier_{v7,v8}_defconfig. Disable the on-board SMC911x because it has not migrated to the driver model yet - it is not possible to enable DM and non-DM drivers at the same time. The CONFIG_SMC911X for uniphier_ld4_sld8_defconfig is still kept because the on-chip ethernet driver for LD4, sLD8 is not supported yet. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-12-26Move CONFIG_PANIC_HANG to KconfigMasahiro Yamada
Freescale (NXP) boards have lots of defconfig files per board. I used "imply PANIC_HANG" for them. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-18configs: Resync with savedefconfigTom Rini
2017-11-29ARM: uniphier: set CONFIG_LOGLEVEL to 6Masahiro Yamada
Print out KERN_NOTICE or higher level log messages. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-23ARM: uniphier: enable DWC3 xHCI driver reallyMasahiro Yamada
I thought commit d37d31849c6a ("ARM: uniphier: enable DWC3 xHCI driver") enabled CONFIG_USB_DWC3_UNIPHIER, but CONFIG_USB_XHCI_DWC3 was missing in uniphier_v7_defconfig. Re-add. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-20net: Add SMC911X driver to Kconfig, convertAdam Ford
We add the various SMC91XX symbols to drivers/net/Kconfig and then this converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_16_BIT CONFIG_SMC911X_32_BIT Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Apply to the rest of the tree, re-squash old and new patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-15ARM: uniphier: enable DWC3 xHCI driverMasahiro Yamada
Enable CONFIGs for the DWC3 core and the UniPhier specific glue layer. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-09-18ARM: uniphier: merge two defconfig files into uniphier_v7_defconfigMasahiro Yamada
The main difference between Pro4 and PXs2/LD6b is the Denali NAND IP version. This is now distinguished by DT. Merge the two defconfig files into uniphier_v7_defconfig. Update the README.uniphier too. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
