path: root/configs/uniphier_ld4_sld8_defconfig
2016-12-29mmc: make MMC driver entries dependent on MMCMasahiro Yamada
Currently, CONFIG_MMC is not related to any other options by "depends on" or "select". One of big advantages of using Kconfig is automatic dependency tracking, but the current state is lacking it. As the first step, make the existing MMC driver entries depend on MMC. This commit was created by the following steps: [1] Run the following script: --------------------8<-------------------- rm -f tmp.txt for d in $(find . -path './configs/*_defconfig') do if grep -q -e 'CONFIG_MSM_SDHCI=y' $d || grep -q -e 'CONFIG_ATMEL_SDHCI=y' $d || grep -q -e 'CONFIG_ROCKCHIP_DWMMC=y' $d || grep -q -e 'CONFIG_SH_SDHI=y' $d || grep -q -e 'CONFIG_PIC32_SDHCI=y' $d || grep -q -e 'CONFIG_ZYNQ_SDHCI=y' $d || grep -q -e 'CONFIG_ROCKCHIP_SDHCI=y' $d || grep -q -e 'CONFIG_MMC_UNIPHIER=y' $d || grep -q -e 'CONFIG_SANDBOX_MMC=y' $d then echo CONFIG_MMC=y >> $d echo ${d#./configs/} >> tmp.txt fi done tools/moveconfig.py -y -s -d tmp.txt rm tmp.txt --------------------8<-------------------- [2] surround MMC driver entries with "if MMC" and "endif" Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-10ARM: uniphier: disable CONFIG_ARCH_FIXUP_FDT_MEMORYMasahiro Yamada
Do not overwrite the memory nodes in the kernel DT where some parts of the memory region might be carved out. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-10-18ARM: dts: uniphier: sync DT with latest LinuxMasahiro Yamada
2016-09-23ARM: uniphier: move CONFIG_SPL_* to defconfig or selectMasahiro Yamada
As I repeated in the ML, I am unhappy with config entries with bare defaults. Kick them out of arch/arm/mach-uniphier/Kconfig. Currently, CONFIG_SPL_SERIAL_SUPPORT is not user-configurable (build fails without it), but it should be fixed later anyway, so I am moving CONFIG_SPL_SERIAL_SUPPORT to defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-19Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL"Masahiro Yamada
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892. I took a closer look at this after the commit was applied, and found CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is actually too big for some boards. Perhaps 0x800 is enough, but the situation varies board by board. Let's postpone our decision until we come up with a better idea. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-18Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2016-09-18ARM: uniphier: select PINCTRL and SPL_PINCTRLMasahiro Yamada
Now all UniPhier SoCs support a pinctrl driver. Select (SPL_)PINCTRL since it is mandatory even for base use. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-16Convert CONFIG_SPL_NOR_SUPPORT to KconfigSimon Glass
2016-09-14usb: uniphier: remove UniPhier xHCI driver and select DM_USBMasahiro Yamada
This driver has not been converted to Driver Model, and it is an obstacle to migrate other block device drivers. Remove it for now. The UniPhier SoCs already use a DM-based EHCI driver, so now ARCH_UNIPHIER can select DM_USB. These two changes must be done atomically because removing the legacy driver causes a build error. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-28ARM: uniphier: enable CONFIG_CMD_CACHEMasahiro Yamada
This will be useful, for example, to load firmware to DRAM and make it visible to other agents. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-28ARM: uniphier: change UNIPHIER_SERIAL to default y optionMasahiro Yamada
This is very likely to be necessary for normal use cases. Set its default to 'y' for shorter defconfig files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-26ARM: uniphier: move CONFIG_I2C_EEPROM to defconfigMasahiro Yamada
We already have the entry for this option in Kconfig, so let's migrate to it. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-20ARM: uniphier: use the default CONFIG_BOOTDELAY=2Masahiro Yamada
I do not insist on CONFIG_BOOTDELAY=3. The default value in Kconfig, CONFIG_BOOTDELAY=2, is just fine for these boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-29ARM: uniphier: rework UniPhier SoC select in KconfigMasahiro Yamada
The chains of "depends on <SoC_name>" in the current Kconfig is clumsy. The idea here is to allow users to choose a SoC group first (SoC group consists of some SoCs that can coexist in one binary). Then, allow to enable/disable each SoC support in the selected SoC group. This makes the Kconfig menu clearer. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29ARM: uniphier: enable UniPhier SD/MMC host driverMasahiro Yamada
Enable the driver in all UniPhier defconfig files and add some needed defines to the common files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29ARM: uniphier: enable GPIO command and driver for UniPhier SoCsMasahiro Yamada
This allows to use the "gpio" command. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-14ARM: uniphier: switch over to generic EHCI driverMasahiro Yamada
The UniPhier EHCI driver (drivers/usb/host/ehci-uniphier.c) does nothing special but set the base address and handle reset/clock. Since commit 4feefdcfe916 ("usb: add clock support for generic EHCI"), the generic one (drivers/usb/host/ehci-generic.c) can do those, too. We no longer need to stick to the dedicated driver. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-23ARM: uniphier: merge ph1_ld4_defconfig and ph1_sld8_defconfigMasahiro Yamada
These two are similar enough to be merged into a single defconfig file. Distinguish one from another by "DEVICE_TREE" from the command line. The how-to-build in doc/README.uniphier should be also updated. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
