2016-02-14 | ARM: uniphier: switch over to generic EHCI driver | Masahiro Yamada | |
The UniPhier EHCI driver (drivers/usb/host/ehci-uniphier.c) does nothing special but set the base address and handle reset/clock. Since commit 4feefdcfe916 ("usb: add clock support for generic EHCI"), the generic one (drivers/usb/host/ehci-generic.c) can do those, too. We no longer need to stick to the dedicated driver. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> | |||
2015-12-23 | ARM: uniphier: merge ph1_ld4_defconfig and ph1_sld8_defconfig | Masahiro Yamada | |
These two are similar enough to be merged into a single defconfig file. Distinguish one from another by "DEVICE_TREE" from the command line. The how-to-build in doc/README.uniphier should be also updated. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> |
