path: root/configs/uniphier_ld20_defconfig
2017-01-22ARM: uniphier: make SPL optional for ARVv8 SoCsMasahiro Yamada
We may want to run different firmware before running U-Boot. For example, ARM Trusted Firmware runs before U-Boot, making U-Boot a non-secure world boot loader. In this case, the SoC might be initialized there, which enables us to skip SPL entirely. This commit removes "select SPL" to make it configurable. This also enables the Multi SoC support for the UniPhier ARMv8 SoCs. (CONFIG_ARCH_UNIPHIER_V8_MULTI) Thanks to the driver model and Device Tree, the U-Boot proper part is now written in a generic way. The board/SoC parameters reside in DT. The Multi SoC support increases the memory footprint a bit, but the U-Boot proper does not have strict memory constraint. This will mitigate the per-SoC (sometimes per-board) defconfig burden. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-17ARM: uniphier: enable Cadence eMMC controller for LD11/LD20Masahiro Yamada
Enable SDMA (Single Operation DMA) for LD11, but not for LD20. The SDMA does not work for LD20 boards because they are generally equipped with more memory than fits in the 32 bit physical address space supported by the SDMA. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-12-29mmc: make MMC driver entries dependent on MMCMasahiro Yamada
Currently, CONFIG_MMC is not related to any other options by "depends on" or "select". One of big advantages of using Kconfig is automatic dependency tracking, but the current state is lacking it. As the first step, make the existing MMC driver entries depend on MMC. This commit was created by the following steps: [1] Run the following script: --------------------8<-------------------- rm -f tmp.txt for d in $(find . -path './configs/*_defconfig') do if grep -q -e 'CONFIG_MSM_SDHCI=y' $d || grep -q -e 'CONFIG_ATMEL_SDHCI=y' $d || grep -q -e 'CONFIG_ROCKCHIP_DWMMC=y' $d || grep -q -e 'CONFIG_SH_SDHI=y' $d || grep -q -e 'CONFIG_PIC32_SDHCI=y' $d || grep -q -e 'CONFIG_ZYNQ_SDHCI=y' $d || grep -q -e 'CONFIG_ROCKCHIP_SDHCI=y' $d || grep -q -e 'CONFIG_MMC_UNIPHIER=y' $d || grep -q -e 'CONFIG_SANDBOX_MMC=y' $d then echo CONFIG_MMC=y >> $d echo ${d#./configs/} >> tmp.txt fi done tools/moveconfig.py -y -s -d tmp.txt rm tmp.txt --------------------8<-------------------- [2] surround MMC driver entries with "if MMC" and "endif" Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-10ARM: uniphier: disable CONFIG_ARCH_FIXUP_FDT_MEMORYMasahiro Yamada
Do not overwrite the memory nodes in the kernel DT where some parts of the memory region might be carved out. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-10-18ARM: dts: uniphier: sync DT with latest LinuxMasahiro Yamada
2016-09-23ARM: uniphier: move CONFIG_SPL_* to defconfig or selectMasahiro Yamada
As I repeated in the ML, I am unhappy with config entries with bare defaults. Kick them out of arch/arm/mach-uniphier/Kconfig. Currently, CONFIG_SPL_SERIAL_SUPPORT is not user-configurable (build fails without it), but it should be fixed later anyway, so I am moving CONFIG_SPL_SERIAL_SUPPORT to defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-19Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL"Masahiro Yamada
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892. I took a closer look at this after the commit was applied, and found CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is actually too big for some boards. Perhaps 0x800 is enough, but the situation varies board by board. Let's postpone our decision until we come up with a better idea. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-18Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2016-09-18ARM: uniphier: select PINCTRL and SPL_PINCTRLMasahiro Yamada
Now all UniPhier SoCs support a pinctrl driver. Select (SPL_)PINCTRL since it is mandatory even for base use. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-16Convert CONFIG_SPL_NOR_SUPPORT to KconfigSimon Glass
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-28ARM: uniphier: enable CONFIG_CMD_CACHEMasahiro Yamada
This will be useful, for example, to load firmware to DRAM and make it visible to other agents. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-28ARM: uniphier: change UNIPHIER_SERIAL to default y optionMasahiro Yamada
This is very likely to be necessary for normal use cases. Set its default to 'y' for shorter defconfig files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-26ARM: uniphier: move CONFIG_I2C_EEPROM to defconfigMasahiro Yamada
We already have the entry for this option in Kconfig, so let's migrate to it. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-20ARM: uniphier: use the default CONFIG_BOOTDELAY=2Masahiro Yamada
I do not insist on CONFIG_BOOTDELAY=3. The default value in Kconfig, CONFIG_BOOTDELAY=2, is just fine for these boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-26ARM: uniphier: revive some commands lost by Kconfig re-syncMasahiro Yamada
The recently added uniphier_ld20_defconfig missed the tree-wide re-sync by commit 89cb2b5f8be4 ("configs: Re-sync with cmd/Kconfig"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-24ARM: uniphier: add PH1-LD20 SoC supportMasahiro Yamada
This is the first ARMv8 SoC from Socionext Inc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
