Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_BOARD_EARLY_INIT_F
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Generated by "tools/moveconfig -s".
This will make config moves easier.
UDOO Neo boards has one FEC port connected to KSZ8091, add support for it.
Tested on a UDOO Neo Full with "dhcp zImage" command.
Signed-off-by: Breno Lima <breno.lima@nxp.com>
It's not necessary to define the processor in the defconfig file.
The preferred method to select the SoC is via Kconfig file.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
UDOO Neo Board is a development board from Seco that has three models:
- UDOO Neo Basic
- UDOO Neo Basic Kick Starter
- UDOO Neo Extended
- UDOO Neo Full
All versions are based on the i.MX6 SoloX processor.
For more details about the UDOO Neo board, please refer to:
http://www.udoo.org/udoo-neo/
This work is based on a previous commit of Francesco Montefoschi
<francesco.monte@gmail.com>:
https://github.com/fmntf/u-boot/commit/877b71184a5105e708024f232d36aed574961844
Only tested on the UDOO Neo Full board.
