path: root/configs/udoo_neo_defconfig
2017-12-18configs: Resync with savedefconfigTom Rini
2017-11-17Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMANDTom Rini
We first introduce CONFIG_USE_BOOTCOMMAND, similar to CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex scheme around this usage, and these have been defered for the moment so that platform maintainers can work on a migration plan. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-19mx6sx: udoo_neo: Enable distro boot options in configPeter Robinson
The include/configs/udoo_neo.h already includes the distro defaults include files so it seems the board was missed in the move to the config file, whether that in initial commit or conversion, so enable the option now and remove duplicated settings. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2016-12-16udoo_neo: Add Ethernet supportBreno Lima
UDOO Neo boards has one FEC port connected to KSZ8091, add support for it. Tested on a UDOO Neo Full with "dhcp zImage" command. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2016-12-16udoo_neo: Move MX6SX configuration to KconfigBreno Lima
It's not necessary to define the processor in the defconfig file. The preferred method to select the SoC is via Kconfig file. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-11-29mx6sx: Add initial support for UDOO Neo BoardBreno Lima
UDOO Neo Board is a development board from Seco that has three models: - UDOO Neo Basic - UDOO Neo Basic Kick Starter - UDOO Neo Extended - UDOO Neo Full All versions are based on the i.MX6 SoloX processor. For more details about the UDOO Neo board, please refer to: http://www.udoo.org/udoo-neo/ This work is based on a previous commit of Francesco Montefoschi <francesco.monte@gmail.com>: https://github.com/fmntf/u-boot/commit/877b71184a5105e708024f232d36aed574961844 Only tested on the UDOO Neo Full board. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
