path: root/configs/udoo_neo_defconfig
2016-12-16udoo_neo: Add Ethernet supportBreno Lima
UDOO Neo boards has one FEC port connected to KSZ8091, add support for it. Tested on a UDOO Neo Full with "dhcp zImage" command. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2016-12-16udoo_neo: Move MX6SX configuration to KconfigBreno Lima
It's not necessary to define the processor in the defconfig file. The preferred method to select the SoC is via Kconfig file. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-11-29mx6sx: Add initial support for UDOO Neo BoardBreno Lima
UDOO Neo Board is a development board from Seco that has three models: - UDOO Neo Basic - UDOO Neo Basic Kick Starter - UDOO Neo Extended - UDOO Neo Full All versions are based on the i.MX6 SoloX processor. For more details about the UDOO Neo board, please refer to: http://www.udoo.org/udoo-neo/ This work is based on a previous commit of Francesco Montefoschi <francesco.monte@gmail.com>: https://github.com/fmntf/u-boot/commit/877b71184a5105e708024f232d36aed574961844 Only tested on the UDOO Neo Full board. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
