Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
CONFIG_CMD_SATA
CONFIG_BOARD_EARLY_INIT_F
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Some boards' defconfigs are disordered. Reorder them.
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig.
Add enable "CONFIG_ARCH_MX6" for boards based on mx6.
Then we can choose target boards using "make ARCH=arm menuconfig"
with ARCH_MX6 defined.
If using original way, we have no chance to enable ARCH_MX6 when
"make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig,
kconfig will complains "arch/../configs/platinum_titanium_defconfig:3:
warning: override: TARGET_PLATINUM_TITANIUM changes choice state"
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Eric Bénard <eric@eukrea.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Soeren Moch <smoch@web.de>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Soeren Moch <smoch@web.de>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Currently we need to build one U-boot image for each of the udoo
variants: quad and dual-lite.
By switching to SPL we can support all two variants with a single binary.
Based on the SPL for wandboard.
Tested with OpenELEC (Open Embedded Linux Entertainment Center)
on both boards.
Signed-off-by: Peter Vicman <peter.vicman@gmail.com>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
