path: root/configs/u200_defconfig
2019-05-31configs: u200: enable support for USB Host & GadgetNeil Armstrong
Now the Amlogic G12A DT and drivers are present, enable full USB on the U200 Reference Design board. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-23boards: meson: add g12a u200Jerome Brunet
The Amlogic U200 board is based on the Amlogic S905D2 SoC from the Amlogic G12A SoC family. The board has the following specifications : - Amlogic S905D2 ARM Cortex-A53 quad-core SoC - XGB DDR4 SDRAM - 10/100 Ethernet (Internal PHY) - 1 x USB 3.0 Host - eMMC - SDcard - Infrared receiver - SDIO WiFi Module - MIPI DSI Connector - Audio HAT Connector - PCI-E M.2 Connector Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
