path: root/configs/turris_omnia_defconfig
2019-05-03arm: mvebu: turris_omnia: enable defconfig options needed by vendorMarek Behún
This options will be enabled by default by CZ.NIC shipped U-Boot. Enable them in defconfig. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: add GPIO support to defconfigMarek Behún
Add support for the gpio command and driver for the I2C connected pca9538 controller, to be able to determine if SFP module is present in the Turris Omnia router. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: move ATSHA204A from defconfig to KconfigMarek Behún
This driver is required for Turris Omnia to read ethernet addresses. Move the dependency from turris_omnia_defconfig to Kconfig. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: use AHCI and SATA driver modelMarek Behún
Enable AHCI, SCSI and SATA for compliance with the driver model migration. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: add XHCI to defconfigMarek Behún
Add XHCI_HOST and XHCI_MVEBU to defconfig, so that user's can by default boot from USB on Turris Omnia. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-04-26arm: mvebu: turris_omnia: Use thumb instructions in SPL to save spaceStefan Roese
With the latest changes to the drivers (SPI_FLASH_SPANSION etc), Travis reports that the SPL image is too big. Let's use the thumb instructions in SPL to save some space and make the image fit again. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Baruch Siach <baruch@tkos.co.il> Cc: Marek Behun <marek.behun@nic.cz> Reviewed-by: Marek Behún <marek.behun@nic.cz>
2019-04-26arm: mvebu: turris_omnia: use MMC driver modelPierre Bourdon
Enable DM_MMC for compliance with the driver model migration. Signed-off-by: Pierre Bourdon <delroth@gmail.com> Cc: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2019-04-12arm: mvebu: turris_omnia: select Kconfig SPI_FLASH_SPANSIONBaruch Siach
Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-02-07Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- SPI-NOR support
2019-02-07configs: Move CONFIG_SPI_FLASH into defconfigsVignesh R
Completely move CONFIG_SPI_FLASH from remaining board header files to defconfigs Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-02-05pci: pci_mvebu: Add DM_PCI support and move CONFIG_PCI_MVEBU to defconfigStefan Roese
This patch adds DM_PCI support to the MVEBU PCIe driver. This is necessary, since all PCI drivers have to be moved to DM (driver model) until the v2019.07 release. To not break git bisect'ablility, this patch also moves CONFIG_PCI_MVEBU from config headers to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Phil Sutter <phil@nwl.cc> Cc: Marek Behún <marek.behun@nic.cz> Cc: VlaoMao <vlaomao@gmail.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-02mvebu: turris_omnia: Add CONFIG_CMD_BTRFS to defconfigMarek Behún
Signed-off-by: Marek Behun <marek.behun@nic.cz>
2017-09-26ARM: mvebu: Convert CONFIG_MVNETA to KconfigChris Packham
This converts the following to Kconfig: CONFIG_MVNETA Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2017-07-25configs: Resync with savedefconfigTom Rini
2017-07-12marvell: armada385: Add the Turris Omnia boardMarek Behún
The Turris Omnia is a open-source router created by CZ.NIC. The code is based on the Marvell/db-88f6820-gp by Stefan Roese with modifications from Tomas Hlavacek in the CZ.NIC turris-omnia-uboot repository, which can be found at https://gitlab.labs.nic.cz/turris/turris-omnia-uboot By default, the Turris Omnia uses btrfs as the main and only filesystem, and also loads kernel and device tree from this filesystem. Since U-Boot does not yet support btrfs, you should not flash your Turris Omnia board with this unless you know what you are doing. Signed-off-by: Tomas Hlavacek <tomas.hlavacek@nic.cz> Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 board/CZ.NIC/turris_omnia/Makefile create mode 100644 board/CZ.NIC/turris_omnia/kwbimage.cfg create mode 100644 board/CZ.NIC/turris_omnia/turris_omnia.c create mode 100644 configs/turris_omnia_defconfig create mode 100644 include/configs/turris_omnia.h Signed-off-by: Stefan Roese <sr@denx.de>
