path: root/configs/tseries_nand_defconfig
2016-02-24board/BuR: move everything possible from board's headerfile to KConfigHannes Schmelzer
We drop everything possible things from board headerfiles and replace this functionality with responsible settings in Kconfig (_defconfig). Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24board/BuR: use default u-boot prompt on all B&R boardsHannes Schmelzer
There is no need to have some specific prompt, so we drop this within defconfigs. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-09-24kconfig: move CONFIG_CMD_CRC32 to KconfigMasahiro Yamada
Since CONFIG_CMD_CRC32 is defined in config_cmd_defaults.h, it is enabled for all the boards except the ones undefining it explicitly: kwb tseries_mmc tseries_nand tseries_spi vct_platinum_onenand_small vct_platinum_small vct_platinumavc_onenand_small vct_platinumavc_small vct_premium_onenand_small vct_premium_small The default value of this config option should be "y" and "# CONFIG_CMD_CRC32 is not set" should be added for those exceptions. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
