path: root/configs/ts4800_defconfig
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30arm: Re-sync ARCH_MX5 / MX51 / MX53 CONFIG optionsTom Rini
A few boards had not been fully re-synced with CONFIG_ARCH_MX5 / CONFIG_MX51 / CONFIG_MX53 being in Kconfig. Do so now. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-02ARM: ts4800: add basic board supportLucile Quirion
This commit adds basic support including: MMC, Serial console, TS4800 watchdog The config use CONFIG_SKIP_LOWLEVEL_INIT as U-boot is used as a second stage bootloader. Signed-off-by: Lucile Quirion <lucile.quirion@savoirfairelinux.com> signed-off-by: Damien Riegel <damien.riegel@savoirfairelinux.com> Cc: Stefano Babic <sbabic@denx.de>
