path: root/configs/tqma6s_wru4_mmc_defconfig
2018-10-22Kconfig: Convert CONFIG_IMX_WATCHDOG to KconfigXiaoliang Yang
Move this option to Kconfig and tidy up the config file of eight boards which use it. Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
2018-02-25bootcount: Migrate CONFIG_SYS_BOOTCOUNT_ADDRTom Rini
Migrate the users of CONFIG_SYS_BOOTCOUNT_ADDR to Kconfig. We can provide a default for BOOTCOUNT_AM33XX as that's a specific part of the RTC in use. We can also provide a default for ARCH_LS1043A and ARCH_LS1021A as they had been previously calculated and their symbols are in Kconfig. In the case of other QE-enabled platforms, they are not so we must update the relevant defconfig files. The previous default only applied in some cases, even on a specific SoC family. Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2016-10-26config: Move CONFIG_DEFAULT_FDT_FILE to defconfigsJagan Teki
- Add DEFAULT_FDT_FILE kconfig entry - Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2015-09-02arm: mx6: Remove SPI support from WRU-IV baseboardStefan Roese
This patch removes the SPI support from the WRU-IV baseboard as its not used at all. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Clemens Gruber <clemens.gruber@pqgruber.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Stefano Babic <sbabic@denx.de> Tested-by: Clemens Gruber <clemens.gruber@pqgruber.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-02arm: mx6: tqma6: fix build for WRU-IV baseboardStefano Babic
Fix: undefined reference to `spi_flash_free' undefined reference to `spi_flash_probe' Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Stefan Roese <sr@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Stefan Roese <sr@denx.de>
2015-07-26arm: mx6: tqma6: Add WRU-IV baseboard for the TQMa6 SoMStefan Roese
This patch adds support for the "OHB System AG" baseboard with is equipped with the TQMa6S SoM. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Stefano Babic <sbabic@denx.de>
