There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
configs/tbs2910_defconfig
configs/tqma6q_mba6_mmc_defconfig
configs/tqma6q_mba6_spi_defconfig
configs/tqma6s_mba6_mmc_defconfig
configs/tqma6s_mba6_spi_defconfig
include/configs/mx6_common.h
this finally removes the need for extra settings in
defconfig
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
Now that we have the Kconfig based CPU type selection,
use this to fill the IMX_CONFIG automatically
This is the first patch to remove the
CONFIG_SYS_EXTRA_OPTIONS.
This patch implements CPU type selection from Kconfig.
Further Kconfig stuff is added later.
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
The QS Systems TQMa6 board support was added by commit cb07d74e
and lost by commit e82abaeb.
Commit e82abaeb merged the IMX branch based on pre-Kconfig
and the mainline based on post-Kconfig, simply deleting
the boards.cfg file. As a result, some boards added just before
the merge were lost.
This commit adds Kconfig, defconfig, MAINTAINERS for TQMa6 board
to work on the Kconfig infrastructure.
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
