CONFIG_SYS_PBSIZE
CONFIG_SYS_MAXARGS
CONFIG_ETHPRIME
This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME
similar to other options that are not always set and control environment
variables.
CONFIG_ARP_TIMEOUT
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_FEC_MXC
Resync all defconfig files using moveconfig.py
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
We have a number of platforms that are a combination of a carrier board
and System-on-Module (SoM) that in turn allows for the board to have
different SoCs on it. In some cases, this is handled via board-specific
Kconfig options. In other cases we make use of
CONFIG_SYS_EXTRA_OPTIONS. This latter case however can lead to invalid
configurations as we will not in turn get options that in Kconfig are
selected by or depend on that setting.
To resolve this, make the SoC option a choice in Kconfig and make boards
depend on what they can support. This change opens us up for further
clean-ups in the cases where a single CONFIG_TARGET_xxx can support
different SoCs and today they do not, or do not cleanly do so.
Reported-by: Matt Porter <mporter@konsulko.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: "NXP i.MX U-Boot Team" <uboot-imx@nxp.com>
Cc: Soeren Moch <smoch@web.de>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Cc: Igor Opaniuk <igor.opaniuk@toradex.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Andreas Geisreiter <ageisreiter@dh-electronics.de>
Cc: Ludwig Zenz <lzenz@dh-electronics.de>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Akshay Bhat <akshaybhat@timesys.com>
Cc: Ken Lin <Ken.Lin@advantech.com.tw>
Cc: Ian Ray <ian.ray@ge.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
Cc: Simone CIANNI <simone.cianni@bticino.it>
Cc: Adam Ford <aford173@gmail.com>
Cc: Marcin Niestroj <m.niestroj@grinn-global.com>
Cc: "Eric Bénard" <eric@eukrea.com>
Cc: Baruch Siach <baruch@tkos.co.il>
Cc: Jason Liu <jason.hui.liu@nxp.com>
Cc: Ye Li <ye.li@nxp.com>
Cc: Eric Nelson <eric@nelint.com>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Parthiban Nallathambi <parthiban@linumiz.com>
Cc: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Niel Fourie <lusus@denx.de>
Cc: Martyn Welch <martyn.welch@collabora.com>
Cc: Richard Hu <richard.hu@technexion.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Boris Brezillon <bbrezillon@kernel.org>
Cc: Arkadiusz Karas <arkadiusz.karas@somlabs.com>
Cc: Breno Lima <breno.lima@nxp.com>
Cc: Francesco Montefoschi <francesco.montefoschi@udoo.org>
Cc: Silvio Fricke <open-source@softing.de>
Tested-by: Matt Porter <mporter@konsulko.com> [colibri_imx6]
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Fixes compilation for WRU4 board.
Signed-off-by: Michael Krummsdorf <michael.krummsdorf@ew.tq-group.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_FSL_USDHC
[trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list]
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
CONFIG_BOARD_EARLY_INIT_F
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Generated by "tools/moveconfig -s".
This will make config moves easier.
- Add DEFAULT_FDT_FILE kconfig entry
- Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
With updated moveconfig.py and an better default, re-generate
the migration of BOOTDELAY to the defconfig.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
