path: root/configs/tqma6q_mba6_spi_defconfig
2015-07-03Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Conflicts: configs/tbs2910_defconfig configs/tqma6q_mba6_mmc_defconfig configs/tqma6q_mba6_spi_defconfig configs/tqma6s_mba6_mmc_defconfig configs/tqma6s_mba6_spi_defconfig include/configs/mx6_common.h Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-27arm: imx6: tqma6: implement KConfig baseboard selectionMarkus Niebel
this finally removes the need for extra settings in defconfig Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2015-06-27arm: imx6: tqma6: boot device selection via KconfigMarkus Niebel
2015-06-27arm: imx6: tqma6: implement IMX_CONFIG with KconfigMarkus Niebel
Now that we have the Kconfig based CPU type selection, use this to fill the IMX_CONFIG automatically Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2015-06-27arm: mx6: tqma6: CPU type selection via KconfigMarkus Niebel
This is the first patch to remove the CONFIG_SYS_EXTRA_OPTIONS. This patch implements CPU type selection from Kconfig. Further Kconfig stuff is added later. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2014-08-31mx6: tqma6: get board support back to Kconfig build systemMasahiro Yamada
The QS Systems TQMa6 board support was added by commit cb07d74e and lost by commit e82abaeb. Commit e82abaeb merged the IMX branch based on pre-Kconfig and the mainline based on post-Kconfig, simply deleting the boards.cfg file. As a result, some boards added just before the merge were lost. This commit adds Kconfig, defconfig, MAINTAINERS for TQMa6 board to work on the Kconfig infrastructure. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Stefano Babic <sbabic@denx.de>
