path: root/configs/tplink_wdr4300_defconfig
2017-05-22Convert CONFIG_LZMA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_LZMA Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-24Move CONFIG_SYS_HUSH_PARSER to Kconfig for last 4 boardsMasahiro Yamada
I still see some defines of this config in board headers. Move them to defconfigs (+ renaming to CONFIG_HUSH_PARSER) to complete this migration. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-02mips: wdr4300: Move the CONFIG_USE_PRIVATE_LIBGCC to KconfigMarek Vasut
This fixes the last remaining libgcc warning, where the symbol was defined twice. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-21mips: ath79: Add support for TPLink WDR4300Marek Vasut
Add support for the TPLink WDR4300 router, which is based on the AR9344 MIPS 74Kc CPU and has 128 MiB of RAM. The USB is supported on this system as well. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Wills Wang <wills.wang@live.com>
