While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances
where these configuration items are conditional on SPL. This commit adds SPL
variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates
the configurations as required.
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
[trini: Make the default depend on the setting for full U-Boot, update
more zynq hardware]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
This patch is doing two things.
1. Exchanging order of boot commands. distro_bootcmd is run first
followed by Xilinx boot command.
2. Remove CONFIG_BOOTCOMMAND from configs (and follow mainline) by
creating Xilinx distribution bootcommand and wiring it as the last
bootcommand.
QSPI, NAND distribution boot command will be added later.
Now that new SPI NOR layer uses stateless 4 byte opcodes by default,
don't enable SPI_FLASH_BAR. For SPI controllers that cannot support
4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c,
renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to
not break functionality.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Tested-by: Stefan Roese <sr@denx.de>
Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
SF_DUAL_FLASH claims to enable support for SF_DUAL_STACKED_FLASH and
SF_DUAL_PARALLEL_FLASH. But, in current U-Boot code, grepping for above
enums yield no user and therefore support seems to be incomplete. Remove
these configs so as to avoid confusion.
Both boards have only controllers enabled that's why move to DM_I2C is
easy.
CONFIG_DEBUG_UART_BASE and CONFIG_DEBUG_UART_CLOCK have changed that's
why this sync.
Now that showing silicon version is part of the CPU
info display, let's remove checkboard().
Note that the generic show_board_info() will still
show the DT 'model' property. For instance:
U-Boot 2018.05-rc2-00025-g611b3ee0159b (Apr 19 2018 - 11:23:12 +0200)
CPU: Zynq 7z045
Silicon: v1.0
Model: Zynq ZC706 Development Board
I2C: ready
Based on patches from Ariel D'Alessandro <ariel@vanguardiasur.com.ar>,
and Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
mini configuration doesn't need to show this information.
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
[trini: Re-run migration after also including CMD_MEMTEST]
Make defconfigs up2date with current location.
This patch added Kconfig support for CONFIG_ZYNQ_I2C0 and
CONFIG_ZYNQ_I2C1 and enabled it in respective defconfig.
Signed-off-by: Vipul Kumar <vipulk@xilinx.com>
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
This patch enabled CONFIG_SYS_I2C_ZYNQ in the respective
defconfig.
This patch added Kconfig support for CONFIG_FPGA_ZYNQPL and migrates the
values over to the defconfigs.
This commit moves USB_FUNCTION_THOR config to Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
BOOTCOMMAND is composed with distro_bootcmd but this variable is not
present. Enabling distro defaults setting is fixing it.
It will cleanup generic config and enable option to change it for every
board.
There are two reasons for doing this change.
There is still !DM driver for xilinx soft gpio IP and especially it is
saving some space for memory constrained boards like cse (almost ~400B).
This patch is fixing two issues:
1. Insufficient stack size for fat fs buffers
2. Insufficient space in malloc area
Tested on zc702 and zc706.
Move cadence/zynq serial driver via Kconfig
Enabling fpga via Kconfig.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
CONFIG_CMD_THOR_DOWNLOAD
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Xilinx changes for v2017.07
ZynqMP:
- config cleanup
- SD LS mode support
- psu_init* cleanup
- unmap OCM
- Support for SMC
Zynq:
- add ddrc to Kconfig
- add topic-miamilite board support
Move the only use of CONFIG_SF_DUAL_FLASH to defconfig. This makes the
associated topic_miamiplus.h header obsolete, so remove that as well.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
Xilinx fixes for v2017.03
- defconfig alignment
- Topic.nl board updates
- Minor microblaze comment fix
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
Allow sending firmware to RAM. Without this, the DFU support was not
of much use.
Keep all defconfig sorted to ensure the smallest diff.
Make the naming scheme consistent; all SDHCI-base drivers prefixed
with CONFIG_MMC_SDHCI_.
While we are here, add "depends on ARCH_ZYNQ || ARCH_ZYNQMP".
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Enable CONFIG_SYS_TEXT_BASE via Kconfig.
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI.
My motivation for the rename is, ultimately, to make all the MMC
options prefixed with MMC_ and SDHCI options with MMC_SDHCI_,
like Linux.
[1] Rename the config option with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g'
[2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig
[3] run "tools/moveconfig.py -y MMC_SDHCI"
[4] add "depends on MMC_SDHCI" to existing SDHCI driver entries
The topic-miami SoMs contain a Zynq xc7z015 or xc7z030 SoC, 1GB DDR3L RAM,
32MB QSPI NOR flash and 256MB NAND flash.
The topic-miamiplus SoMs contain a Zynq xc7z035, xc7z045 or xc7z100 SoC,
2x 1GB DDR3L RAM, 64MB dual-parallel QSPI flash, clock sources
and a fan controller.
The "Florida" carrier boards add SD, USB, ethernet and other interfaces.
