path: root/configs/topic_miamilite_defconfig
2019-02-22configs: Resync with savedefconfigTom Rini
2019-02-14ARM: zynq: Run distribution boot commands firstMichal Simek
This patch is doing two things. 1. Exchanging order of boot commands. distro_bootcmd is run first followed by Xilinx boot command. 2. Remove CONFIG_BOOTCOMMAND from configs (and follow mainline) by creating Xilinx distribution bootcommand and wiring it as the last bootcommand. QSPI, NAND distribution boot command will be added later. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-02-07configs: Remove SF_DUAL_FLASHVignesh R
SF_DUAL_FLASH claims to enable support for SF_DUAL_STACKED_FLASH and SF_DUAL_PARALLEL_FLASH. But, in current U-Boot code, grepping for above enums yield no user and therefore support seems to be incomplete. Remove these configs so as to avoid confusion. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-01-24ARM: zynq: Convert Topic Miami to DM_I2CMichal Simek
Both boards have only controllers enabled that's why move to DM_I2C is easy. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-06-04xilinx: Sync symbols location in defconfigsMichal Simek
CONFIG_DEBUG_UART_BASE and CONFIG_DEBUG_UART_CLOCK have changed that's why this sync. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-11arm: zynq: Remove checkboard and enable DISPLAY_CPUINFOMichal Simek
Now that showing silicon version is part of the CPU info display, let's remove checkboard(). Note that the generic show_board_info() will still show the DT 'model' property. For instance: U-Boot 2018.05-rc2-00025-g611b3ee0159b (Apr 19 2018 - 11:23:12 +0200) CPU: Zynq 7z045 Silicon: v1.0 Model: Zynq ZC706 Development Board I2C: ready Based on patches from Ariel D'Alessandro <ariel@vanguardiasur.com.ar>, and Ezequiel Garcia <ezequiel@vanguardiasur.com.ar> mini configuration doesn't need to show this information. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-23xilinx: Sync defconfigs with latest Kconfig updatesMichal Simek
Make defconfigs up2date with current location. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-03-01i2c: Added kconfig support for CONFIG_ZYNQ_I2C0 and CONFIG_ZYNQ_I2C1Vipul Kumar
This patch added Kconfig support for CONFIG_ZYNQ_I2C0 and CONFIG_ZYNQ_I2C1 and enabled it in respective defconfig. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-03-01i2c: Enabled CONFIG_SYS_I2C_ZYNQ in the respective defconfigVipul Kumar
This patch enabled CONFIG_SYS_I2C_ZYNQ in the respective defconfig. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-02-28arm: zynq: fpga: Added Kconfig support for CONFIG_FPGA_ZYNQPLVipul Kumar
This patch added Kconfig support for CONFIG_FPGA_ZYNQPL and migrates the values over to the defconfigs. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-02Kconfig: gadget: Move CONFIG_USB_FUNCTION_THOR to KconfigLukasz Majewski
This commit moves USB_FUNCTION_THOR config to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Acked-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-30arm: zynq: Enable distro defaults settingMichal Simek
BOOTCOMMAND is composed with distro_bootcmd but this variable is not present. Enabling distro defaults setting is fixing it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Move bootcommand to defconfigMichal Simek
It will cleanup generic config and enable option to change it for every board. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Enable DM_GPIO when neededMichal Simek
There are two reasons for doing this change. There is still !DM driver for xilinx soft gpio IP and especially it is saving some space for memory constrained boards like cse (almost ~400B). Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-14arm: zynq: Fix SPL SD boot modeMichal Simek
This patch is fixing two issues: 1. Insufficient stack size for fat fs buffers 2. Insufficient space in malloc area Tested on zc702 and zc706. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm: zynq: Move ZYNQ_SERIAL to KconfigMichal Simek
Move cadence/zynq serial driver via Kconfig Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-28arm: zynq: Enable FPGA/FPGA_XILINX via KconfigMichal Simek
Enabling fpga via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-11Convert CONFIG_CMD_THOR_DOWNLOAD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_THOR_DOWNLOAD Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-10configs: Resync defconfigsTom Rini
2017-06-20arm: zynq: Add support for the topic-miamilite system-on-moduleMike Looijmans
The topic-miamilite SoM contains a Zynq xc7z010 SoC, 1GB DDR3L RAM, 64MB dual-parallel QSPI NOR flash and clock sources. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
