path: root/configs/topic_miamilite_defconfig
2017-08-11Convert CONFIG_CMD_THOR_DOWNLOAD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_THOR_DOWNLOAD Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-10configs: Resync defconfigsTom Rini
2017-06-20arm: zynq: Add support for the topic-miamilite system-on-moduleMike Looijmans
The topic-miamilite SoM contains a Zynq xc7z010 SoC, 1GB DDR3L RAM, 64MB dual-parallel QSPI NOR flash and clock sources. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
