path: root/configs/topic_miami_defconfig
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-11-15ARM: zynq: Add support for the topic-miami system-on-modules and carrier boardsMike Looijmans
The topic-miami SoMs contain a Zynq xc7z015 or xc7z030 SoC, 1GB DDR3L RAM, 32MB QSPI NOR flash and 256MB NAND flash. The topic-miamiplus SoMs contain a Zynq xc7z035, xc7z045 or xc7z100 SoC, 2x 1GB DDR3L RAM, 64MB dual-parallel QSPI flash, clock sources and a fan controller. The "Florida" carrier boards add SD, USB, ethernet and other interfaces. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
