path: root/configs/tny_a9g20_nandflash_defconfig
2015-05-13ARM: at91: remove non-generic boardsMasahiro Yamada
Remove board support for afeb9260, tny_a9260, and sbc35_a9g20. They have not been converted into Generic Board yet. See doc/README.generic-board for details. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
