CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
Add a proper Kconfig option for SPL so we can remove the hack in some of
the board config files.
This involves adding CONFIG_SPL_DM_PMIC to some of the configs as well
as updateing the Makefile rule for PMIC_RK8XX to exclude SPL.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Add SPL_PMIC_RK8XX, enable when needed, handle undef of
CONFIG_DM_PMIC_PFUZE100 as well]
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Rename this option so that CONFIG_IS_ENABLED can be used with it.
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
These boards aren't ChromeOS devices so won't have a cros-ec-keyb
input as it's the keyboard available via the ChromeOS Embedded
Controller. Update them to use a USB keyboard which would actually
be available. Also enable the usb keyboard option for those devices
that don't have it enabled already.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Enable HDMI output for Tinker RK3288 board.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
RK3288, RK3399 are now support cpu-info, so enable
DISPLAY_CPUINFO by default.
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- Clean vid/pid in Kconfig and add fastboot for rk3399
- add 'u-boot, spl-fifo-mode' for mmc
- Use FIT generator for rk3229 optee and rk3368 ATF
- fan53555: add support for Silergy SYR82X and SYR83X
Select CONFIG_FASTBOOT_FLASH, CONFIG_FASTBOOT_FLASH_MMC_DEV
for rockchip SoC plaforms in fastboot Kconfig file instead
of defined it in board defconfig.
This eventually drop the explicit configs defined in
supporting board defconfig files.
Tested-by: Levin Du <djw@t-chip.com.cn>
Rockchip support differnet or common gadget product number
between Rockchip SoCs like,
0x310a - rk3036
0x320a - rk3229, rk3288
0x330a - rk3328
So, select them on Kconfig based on platform specific
config defined.
Gadget vendor number, 0x2207 is common across all platfroms
supported in Rockchip SoC.
So, select the same number globally, if ARCH_ROCKCHIP.
This eventually drop the explicit configs defined in supported
Select the gadget manufacturer as 'Rockchip' for
all rockchip platform SoC's.
This eventually drop the explicit defined added
on supported board defconfig files.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
This is currently a decimal value which is not as convenient or
meaningful. Also U-Boot tends to use hex everywhere.
Convert this option to hex and add a comment for the size_check macro.
Acked-by: Bin Meng <bmeng.cn@gmail.com>
[bmeng: correct the typo in the commit title]
Tinker board needs to mux all the sdmmc gpio and
activate the regulator connected to bank 7. Remove
all the bank that are not in use and mark them as dm,spl
so-that it would initialize at SPL.
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Reviewed-by: Kever Yang<kever.yang@rock-chips.com>
SPL sets up SDRAM while in its board_init_f()
function, it is possible for the stack to move
there before board_init_r() is reached.
So it is required to reserve the stack for SDRAM,
with a proper location and size otherwise any
operations during SPL handoff would leads to failure.
On, this particular context tinker-rk3288 SPL is
failing to launch U-Boot proper on SDRAM due to
lack of stack.
U-Boot SPL 2019.10-rc3-00297-g5ba8b12543 (Sep 12 2019 - 08:50:36 +0530)
Trying to boot from MMC1
spl: mmc init failed with error: -110
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
So, enable SPL_STACK_R_ADDR and it's related-config
items for SDRAM, SPL stack to setup properly.
Reported-by: Jagan Teki <jagan@amarulasolutions.com>
SPL_TEXT_BASE is 0x0 by default, based on the kconfig
definition move in below commit.
"configs: move CONFIG_SPL_TEXT_BASE to Kconfig"
(sha1: f89d6133eef2e068f9c33853b6584d7fcbfa9d2e)
So, don't define it explicitly.
This affects RK3036, RK322X and RK3288 - the defconfig changes done by
moveconfig.py for the veyrons were left out on purpose because they dont
have an OTG port, and will get their config updated in the next commit.
Signed-off-by: Urja Rannikko <urjaman@gmail.com>
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
We share the same TPL_LDSCRIPT for all rk3288 board, add
default value in Kconfig.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
There is no difference in rk3288 board use for SYS_MALLOC_F_LEN,
so we can use default value.
We need to update TEXT BASE for TPL/SPL/U-Boot;
SPL no need relocate STACK after enable TPL, so remove it;
Don't enable pinctrl names so that SPL can get pinctrl dts;
The SPL for the Tinker Board has to fit into 32 KiB. Currently this limit
is exceeded.
CONFIG_SPL_I2C_SUPPORT is not needed to move to main U-Boot. So let's
disable it.
Suggested-by: David Wu <david.wu@rock-chips.com>
Reviewed-by: David Wu <david.wu@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The SPL image for the Tinker Board has to fit into 32 KiB. This includes
up to 2 KiB for the file header.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_MODE
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Completely move CONFIG_SPI_FLASH from remaining board header files to
defconfigs
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
If we used the pinctrl-rockchip driver, these config is not needed,
so remove them.
Signed-off-by: David Wu <david.wu@rock-chips.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
