path: root/configs/ti816x_evm_defconfig
2017-12-18configs: Resync with savedefconfigTom Rini
2017-11-17Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMANDTom Rini
We first introduce CONFIG_USE_BOOTCOMMAND, similar to CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex scheme around this usage, and these have been defered for the moment so that platform maintainers can work on a migration plan. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-29TI: ARCH_OMAP2PLUS: Enable SPL_STACK_R and provide default valueTom Rini
On ARCH_OMAP2PLUS platforms we know what the DDR layout is going to be, and that it is safe to use SPL_STACK_R and provide a default value for it. select this and re-sync the defconfigs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13Convert CONFIG_OMAP3_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP3_SPI Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Minor comment tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-10Convert CONFIG_SYS_I2C_OMAP24XX to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_OMAP24XX Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11ARM: ti816x: Fix enabling GPIO0, enable GPIO1 as wellTom Rini
The TI816x has 2 GPIO banks. For bank 0 we had been clearing the enable bit when setting BIT(8). Correct this by setting it to BIT(1) | BIT(8) after we set and wait for BIT(1) (aka PRCM_MOD_EN). Enable GPIO1 as well so that when CMD_GPIO is enabled it won't crash probing the second bank. Enable CMD_GPIO on ti816x_evm. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11ti816x: Enable ethernet supportTom Rini
The ti816x SoC revision of the ethernet IP block is handled by the "davinci_emac" driver, rather than the "cpsw" driver as done by later members of the family. Enable the relevant plumbing. Signed-off-by: Sriramakrishnan <srk@ti.com> Signed-off-by: Vitaly Wool <vitaly.wool@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-10configs: Resync defconfigsTom Rini
2017-06-28ti816x: Enable ethernet supportTom Rini
2017-06-05t81xx: Migrate TI81XX/TI816X/TI814X symbols to KconfigTom Rini
The symbol CONFIG_TI81XX is used for the parts that are common to the TI816x and TI814x SoCs and are not part of CONFIG_ARCH_OMAP2PLUS nor CONFIG_AM33XX. It however has so few uses that we can just modify the code to check for both and drop the symbol. The symbols CONFIG_TI816X and CONFIG_TI814X are for the repective SoCs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-05ti816x: Modernize the defconfigTom Rini
- Switch to using <configs/ti_armv7_omap.h> and family. This lets us drop lots of custom defines. - Ensure that our default environment uses DEFAULT_LINUX_BOOT_ENV so that Linux will boot correctly. - Enable CONFIG_DISTRO_DEFAULTS - Switch to using CONFIG_OF_CONTROL - Various other cleanups to match other SoCs in the family line. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-05ti816x: Enable NANDTom Rini
The TI8168-EVM comes with NAND on board. Enable it and move environment over there. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-05ti816x_evm: Disable CONFIG_USE_PRIVATE_LIBGCCTom Rini
On this platform, we can trace a general failure to boot to enabling / disabling this option. When this is enabled, we go off into the weeds during SPL and are unable to talk with the SD card and mmc_initialize() fails. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_YMODEM_SUPPORT to KconfigSimon Glass
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig Move this option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
