path: root/configs/thunderx_88xx_defconfig
2016-07-25arm64: thunderx_88xx_defconfig: remove unneeded CONFIG_SYS_EXTRA_OPTIONSMasahiro Yamada
ARM64 is correctly select'ed in arch/arm/Kconfig, so this line in the defconfig is unneeded. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27net: Move the VCI and client arch values to KconfigAlexander Graf
We have a bunch of boards that define their vendor class identifier and client archs in the board files or in the distro config. Move everything to the generic Kconfig options. We're missing the distinction between i386 and x86_64, as I couldn't find any config variable that would tell us the difference. Is that really important to people? I guess not, so I left it out. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-19armv8: cavium: Add ThunderX 88xx board definitionSergey Temerkhanov
This commit adds basic Cavium ThunderX 88xx board definitions and support. Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> [trini: Drop CONFIG_SYS_GENERIC_BOARD define] Signed-off-by: Tom Rini <trini@konsulko.com>
