path: root/configs/thuban_defconfig
2015-06-19siemens,am33x,thuban: rename dxr2 to thubanHeiko Schocher
Update new naming scheme. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
