This converts CONFIG_DRIVER_TI_CPSW to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
This converts CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC to Kconfig
CONFIG_BOOTCOUNT_ENV
Reviewed-by: Lukasz Majewski <lukma@denx.de>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
CONFIG_BOOTCOUNT_LIMIT
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
CONFIG_USB_MUSB_OMAP2PLUS
CONFIG_USB_MUSB_AM35X
CONFIG_USB_MUSB_DSPS
CONFIG_USB_MUSB_PIO_ONLY
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The USB Ethernet gadget option has not yet been moved to Kconfig, let's
deal with that.
Reviewed-by: Ćukasz Majewski <lukma@denx.de>
CONFIG_OMAP3_SPI
[trini: Minor comment tweaks]
CONFIG_NAND
[trini: Sync up a few more, add imply's]
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_SYS_TEXT_BASE
The includes, whitelist, etc. were left for now but I don't get any
build errors or warnings on the omap3_logic_defconfig or
am3517_evm_defconfig builds I tried.
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Almost all users of CONFIG_AM33XX/AM43XX have been migrated. Finish
moving the last few over to Kconfig, and put all of the boards under the
appropriate Kconfig chocie now. This board choice is non-optional, so
remove that keyword on am33xx.
Move this entry to Kconfig. As it is a hardware watchdog, select
HW_WATCHDOG. While we could default to enabling this for all platforms,
it is currently only enabled by default on AM33XX, so keep that logic
today.
Cc: Roger Meier <r.meier@siemens.com>
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs.
Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this
naming.
Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim
down the arch/arm/Kconfig level.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_ARCH_MISC_INIT
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Move (and rename) the following CONFIG options to Kconfig:
CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI)
CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS)
CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC)
CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS)
CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA)
CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI)
They are the same option names as used in Linux.
This commit was created as follows:
[1] Rename the options with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e '
s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g
s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g
s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g
s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g
s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g
s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g
[2] Commit the changes
[3] Create entries in driver/mmc/Kconfig.
(copied from Linux)
[4] Move the options with the following command
tools/moveconfig.py -y -r HEAD \
MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI
[5] Sort and align drivers/mmc/Makefile for readability
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Fix sniper and kc1 migration]
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
