Done with:
./tools/moveconfig.py BMP_16BPP BMP_24BPP BMP_32BPP
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Update mvebu SPL boot selection mechanism for the move to driver model
usage by ensuring that the required driver support for SPI and MMC
booting is available in SPL when the respective boot method is
selected.
Previously, all mvebu boards selected a boot method (implicitly
MVEBU_SPL_BOOT_DEVICE_SPI for many) even if SPL booting wasn't used.
This changes mvebu boot method selection to depend on SPL usage which
resolves the issue with aarch64 boards which don't use SPL getting an
implicit boot device selection resulting in unmet dependencies. The
32-bit arm boards do use SPL, but I'm led to conclude that most aren't
intentionally using the MVEBU_SPL_BOOT_DEVICE selection since none have
SPL_DM_SPI enabled in their defconfig even though they still implicitly
select the SPI boot method.
This also results in the new addition of SPL_GPIO_SUPPORT to helios4.
The mainline dts for helios4 includes the cd-gpios entry for sdhci with
identical addresses as the clearfog dts. I don't have a helios4 board
to confirm, but based on the current source conclude that the board
itself is either wired to pull the signal low for eMMC, or the default
MMC boot isn't fully functional in mainline. In either case, as far as
I can tell, including the GPIO support will at least cause no
regression.
Tested on SolidRun ClearFog devices.
Signed-off-by: Joel Johnson <mrjoel@lixil.net>
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_SYS_SPI_U_BOOT_OFFS
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
This patch enables CONFIG_BLK as this is now possible with the recent
DM conversion of the Armada XP SATA driver.
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT
with same value is used, so I introduced CONFIG_USE_ENV_SPI_*
to force the associated value for the environment.
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
This patch moves the Armada XP video / LCD driver to DM_VIDEO. With this
move, the legacy interface board_video_init() is removed from the
theadorable board code (only user of this video driver). The support
via DT will be added in a separate patch.
This patch also enables DM_VIDEO for the theadorable board, as this is
needed to not break git bisect'ability.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
Acked-by: Anatolij Gustschin <agust@denx.de>
This patch adds DM_PCI support to the MVEBU PCIe driver. This is
necessary, since all PCI drivers have to be moved to DM (driver model)
until the v2019.07 release.
To not break git bisect'ablility, this patch also moves CONFIG_PCI_MVEBU
from config headers to the defconfig files.
Cc: Dirk Eibach <dirk.eibach@gdsys.cc>
Cc: Mario Six <mario.six@gdsys.cc>
Cc: Chris Packham <chris.packham@alliedtelesis.co.nz>
Cc: Phil Sutter <phil@nwl.cc>
Cc: Marek BehĂșn <marek.behun@nic.cz>
Cc: VlaoMao <vlaomao@gmail.com>
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
The CONFIG_PHY_MARVELL has already been migrated to Kconfig (some boards
already had it in their Kconfig), but had not been moved for older
boards.
Move it to the defconfigs for all boards.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
CONFIG_BOOTCOUNT_RAM
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
CONFIG_BOOTCOUNT_LIMIT
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
The setexpr command is useful for scripting, lets enable it for this
platform.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
CONFIG_MVNETA
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_CMD_PCI
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_FPGA
CONFIG_FPGA_ALTERA
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
