Rsync all defconfig files using moveconfig.py and update
scripts/pylint.base
CONFIG_SCSI_AHCI_PLAT
CONFIG_SYS_SCSI_MAX_SCSI_ID
CONFIG_SYS_SCSI_MAX_LUN
CONFIG_SYS_SATA_MAX_DEVICE
Drop CONFIG_SCSI for everything except the sandbox build. We only need
one build for tests.
Move the SATA options inside an 'if SATA' part, so they are grouped.
Fix the 'Complient' typo while we are here.
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
As part of this, we use Kconfig to provide the defaults now that were
done in include/spi_flash.h. We also in some cases change from using
CONFIG_ENV_SPI_FOO to CONFIG_SF_DEFAULT_FOO as those were the values in
use anyhow as ENV was not enabled.
Move to the DM I2C version, so that this board will not get dropped from
mainline.
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SYS_I2C_SPEED
CONFIG_SYS_I2C_SLAVE
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
CONFIG_SYS_I2C_MVTWSI
Now that proper load and execution addresses are set in v1 kwbimage we
can use it for loading and booting U-Boot proper.
Use the new spl_parse_board_header() function to implement parsing the
kwbimage v1 header. Use information from this header to locate offset and
size of the U-Boot proper binary, instead of using the legacy U-Boot
header which is prepended to the U-Boot proper binary stored at fixed
offset. This has the advantage that we do not need to relay on legacy
U-Boot header anymore and therefore U-Boot proper binary can be stored at
any offset, as is the case when loading & booting U-Boot proper by
BootROM. The CONFIG_SYS_U_BOOT_OFFS option is therefore not used by SPL
code anymore.
Also allow to compile U-Boot SPL without CONFIG_SPL_SPI_FLASH_SUPPORT,
CONFIG_SPL_MMC_SUPPORT or CONFIG_SPL_SATA_SUPPORT set. In this case
BootROM is used for loading and executing U-Boot proper. This reduces the
size of U-Boot's SPL image. By default these config options are enabled
and so BootROM loading is not used. In some cases BootROM reads from SPI
NOR at lower speed than U-Boot SPL. So people can decide whether they
want to have smaller SPL binary at the cost of slower boot.
Therefore dependency on CONFIG_SPL_DM_SPI, CONFIG_SPL_SPI_FLASH_SUPPORT,
CONFIG_SPL_SPI_LOAD, CONFIG_SPL_SPI_SUPPORT, CONFIG_SPL_DM_GPIO,
CONFIG_SPL_DM_MMC, CONFIG_SPL_GPIO_SUPPORT, CONFIG_SPL_LIBDISK_SUPPORT,
CONFIG_SPL_MMC_SUPPORT, CONFIG_SPL_SATA_SUPPORT and
CONFIG_SPL_LIBDISK_SUPPORT is changed from strict to related "imply"
(which can be selectivelly turned off and causes booting via BootROM).
Options CONFIG_SYS_SPI_U_BOOT_OFFS,
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR and
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET have to to be set to
zero as they define the location where kwbimage header starts. It is the
location where BootROM expects start of the kwbimage from which it reads,
parses and executes SPL part. The same applies to option
CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR, which has to be set to one.
Update all config files to set correct values of these options and set
CONFIG_SYS_U_BOOT_OFFS to the correct value - the offset where U-Boot
proper starts.
Signed-off-by: Pali Rohár <pali@kernel.org>
Reviewed-by: Marek Behún <marek.behun@nic.cz>
Done with:
./tools/moveconfig.py BMP_16BPP BMP_24BPP BMP_32BPP
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Update mvebu SPL boot selection mechanism for the move to driver model
usage by ensuring that the required driver support for SPI and MMC
booting is available in SPL when the respective boot method is
selected.
Previously, all mvebu boards selected a boot method (implicitly
MVEBU_SPL_BOOT_DEVICE_SPI for many) even if SPL booting wasn't used.
This changes mvebu boot method selection to depend on SPL usage which
resolves the issue with aarch64 boards which don't use SPL getting an
implicit boot device selection resulting in unmet dependencies. The
32-bit arm boards do use SPL, but I'm led to conclude that most aren't
intentionally using the MVEBU_SPL_BOOT_DEVICE selection since none have
SPL_DM_SPI enabled in their defconfig even though they still implicitly
select the SPI boot method.
This also results in the new addition of SPL_GPIO_SUPPORT to helios4.
The mainline dts for helios4 includes the cd-gpios entry for sdhci with
identical addresses as the clearfog dts. I don't have a helios4 board
to confirm, but based on the current source conclude that the board
itself is either wired to pull the signal low for eMMC, or the default
MMC boot isn't fully functional in mainline. In either case, as far as
I can tell, including the GPIO support will at least cause no
regression.
Tested on SolidRun ClearFog devices.
Signed-off-by: Joel Johnson <mrjoel@lixil.net>
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
This patch enables CONFIG_BLK as this is now possible with the recent
DM conversion of the Armada XP SATA driver.
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT
with same value is used, so I introduced CONFIG_USE_ENV_SPI_*
to force the associated value for the environment.
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
This patch moves the Armada XP video / LCD driver to DM_VIDEO. With this
move, the legacy interface board_video_init() is removed from the
theadorable board code (only user of this video driver). The support
via DT will be added in a separate patch.
This patch also enables DM_VIDEO for the theadorable board, as this is
needed to not break git bisect'ability.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
Acked-by: Anatolij Gustschin <agust@denx.de>
This patch adds DM_PCI support to the MVEBU PCIe driver. This is
necessary, since all PCI drivers have to be moved to DM (driver model)
until the v2019.07 release.
To not break git bisect'ablility, this patch also moves CONFIG_PCI_MVEBU
from config headers to the defconfig files.
Cc: Dirk Eibach <dirk.eibach@gdsys.cc>
Cc: Mario Six <mario.six@gdsys.cc>
Cc: Chris Packham <chris.packham@alliedtelesis.co.nz>
Cc: Phil Sutter <phil@nwl.cc>
Cc: Marek Behún <marek.behun@nic.cz>
Cc: VlaoMao <vlaomao@gmail.com>
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
The CONFIG_PHY_MARVELL has already been migrated to Kconfig (some boards
already had it in their Kconfig), but had not been moved for older
boards.
Move it to the defconfigs for all boards.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
CONFIG_BOOTCOUNT_RAM
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
