path: root/configs/theadorable_debug_defconfig
2018-02-24Convert CONFIG_BOOTCOUNT_RAM to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_RAM Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-12-12ata: Migrate CONFIG_SATA_MV to KconfigTuomas Tynkkynen
2017-11-16arm: mvebu: theadorable_debug_defconfig: Enable setexpr commandStefan Roese
The setexpr command is useful for scripting, lets enable it for this platform. Signed-off-by: Stefan Roese <sr@denx.de>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-09-26ARM: mvebu: Convert CONFIG_MVNETA to KconfigChris Packham
This converts the following to Kconfig: CONFIG_MVNETA Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2017-07-26kconfig: Convert FPGA and FPGA_ALTERA configuration to KconfigTien Fong Chee
This converts the following to Kconfig: CONFIG_FPGA CONFIG_FPGA_ALTERA Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-19Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL"Masahiro Yamada
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892. I took a closer look at this after the commit was applied, and found CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is actually too big for some boards. Perhaps 0x800 is enough, but the situation varies board by board. Let's postpone our decision until we come up with a better idea. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-24arm: mvebu: theadorable: Add StratixV FPGA programming supportStefan Roese
This patch adds support for Altera StratixV bitstream programming. 2 FPGAs are connected to the SPI busses. This patch uses board specific write code to program the bitstream via SPI direct write mode. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-27arm: mvebu: Add support for the Armada XP theadorable boardStefan Roese
This patch adds support for the Armada XP (MV78260) based theadorable board. Its equipped with onboard DDR3, UART, ethernet, I2C, SPI NOR, LCD and SATA (SSD) interfaces / devices. Two defconfigs are added: theadorable_defconfig: The production U-Boot version with a stripped down drivers and feature list. This removes networking, USB and PCI support. theadorable_debug_defconfig: The debugging / testing U-Boot version with full support for all drivers. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
