path: root/configs/theadorable-x86-conga-qa3-e3845_defconfig
2018-10-28x86: theadorable-x86-xxx_defconfig: Move VGA BIOS to make room for U-BootStefan Roese
The build breaks because its not fitting the U-Boot binary into the ROM image. So lets move VGA BIOS a bit to make room for the grown U-Boot binary. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-28x86: theadorable-x86: Generate and pass root=PARTUUID instead of /dev/sdaXStefan Roese
To enable the root device selection (kernel cmd-line) via PARTUUID, this patch enables CMD_PART on all missing theadorable-x86 boards and changes the default environment to generate the root=PARTUUID string automatically. This fixes problems that have been noticed on systems with multiple SATA/AHCI controller connected via PCIe, where the device name for the root device / partition (/dev/sdaX) was incorrect. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-10-07x86: theadorable-x86-xxx_defconfig: Enable setexpr commandStefan Roese
The setexpr command is useful for scripting, lets enable it for all x86 based theadorable platforms. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-08x86: conga: theadorable-x86-conga-qa3-e3845_defconfig: Misc defconfig updatesStefan Roese
- Disable debug UART - Enable more partition support Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-08x86: conga: Add option to select different config headers for baseboardsStefan Roese
This patch adds the infrastructure to define different config headers with different configurations and default environment for the baseboards that can now be selected via Kconfig. The new configuration for the theadorable-x86-conga-qa3-e3845 is also added. Also the new defconfig file for this new target is added. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
