path: root/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig
2018-10-28x86: theadorable-x86-xxx_defconfig: Move VGA BIOS to make room for U-BootStefan Roese
The build breaks because its not fitting the U-Boot binary into the ROM image. So lets move VGA BIOS a bit to make room for the grown U-Boot binary. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-28x86: theadorable-x86: Generate and pass root=PARTUUID instead of /dev/sdaXStefan Roese
To enable the root device selection (kernel cmd-line) via PARTUUID, this patch enables CMD_PART on all missing theadorable-x86 boards and changes the default environment to generate the root=PARTUUID string automatically. This fixes problems that have been noticed on systems with multiple SATA/AHCI controller connected via PCIe, where the device name for the root device / partition (/dev/sdaX) was incorrect. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-10-07x86: theadorable-x86-xxx_defconfig: Enable setexpr commandStefan Roese
The setexpr command is useful for scripting, lets enable it for all x86 based theadorable platforms. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-08x86: Add defconfig for theadorable-x86-conga with PCIe x4 blobsStefan Roese
This defconfig uses the PCIe x4 binary blobs from the congatec BIOS. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
