Commit 08574ed339fb ("Convert CONFIG_SYS_MONITOR_LEN to Kconfig") moved
the definition of said config variable from the common sunxi header to
*every board's* defconfig.
This is a platform choice, not board specific, so remove the variable
from there, instead set the one value for all Allwinner boards in
Kconfig.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Jernej Skrabec <jernej.skrabec@gmail.com>
To do this, we set a default of 0 for everyone because there are a
number of cases where we define CONFIG_SYS_MONITOR_LEN but the only
impact is that we set TOTAL_MALLOC_LEN to be CONFIG_SYS_MALLOC_LEN +
CONFIG_ENV_SIZE, so we must continue to allow all boards to set this
value. Update the SPL code to use 200 KB as the default raw U-Boot size
directly, if we don't have a real CONFIG_SYS_MONITOR_LEN value.
When some configuration symbols were converted from header files to
Kconfig, their values were placed into *every* defconfig file.
Since we now have sensible per-SoC defaults defined in Kconfig, those
values are now redundant, and can just be removed.
This affects CONFIG_SPL_STACK, CONFIG_SYS_PBSIZE, CONFIG_SPL_MAX_SIZE,
and CONFIG_SYS_BOOTM_LEN.
As part of this, rework error handling in boot/bootm.c so that we pass
the buffer size to handle_decomp_error as CONFIG_SYS_BOOTM_LEN will not
be available to host tools but we do know the size that we passed to
malloc().
Cc: Soeren Moch <smoch@web.de>
CONFIG_SPL_STACK
CONFIG_SYS_PBSIZE
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
CONFIG_SYS_I2C_MVTWSI
A64-Teres-I board is a laptop which comes with a builtin keyboard.
The keyboard+trackpad controller pauses for 2 seconds at a firmware
prompt before loading its HID interface.
U-Boot needs to wait equally long to reliably enable the keyboard.
Signed-off-by: Jonas Smedegaard <dr@jones.dk>
Series-Cc: Jagan Teki <jagan@amarulasolutions.com>
Series-Cc: Lukasz Majewski <lukma@denx.de>
Series-Cc: Andre Przywara <andre.przywara@arm.com>
Now that those common Allwinner config symbols are defined automatically
for all boards in their Kconfig files, we can remove the now redundant
definitions from the boards' _defconfig files.
Some boards had a differing definiton for some of those symbols, it
looks like mostly to "merge races" when the symbol was introduced (new
board *_defconfig file missed the "add symbol to all files" patch).
Acked-by: Maxime Ripard <mripard@kernel.org>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
The choice of the SPL_TEXT_BASE is not really a decision that should be
specified by each board's defconfig, as this setting is actually
dictated by the SoC's memory map and the BootROM behaviour.
To make this obvious and reduce the clutter in the defconfig files,
let's specify the SoC constraints in the Kconfig stanza.
This allows us to remove these lines from the defconfig files again.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
SPL_TEXT_BASE was moved into Kconfig, which previously part of
include/configs before this teres_i support gets merged.
Fix it by explicitly define in defconfig like other boards does.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Olimex A64-Teres-I board is a mainboard (the only one so far)
for Olimex Teres-I DIY laptop kit.
Key features:
- Allwinner A64 Cortex-A53
- Mali-400MP2 GPU
- AXP803 PMIC
- 2GB DDR3 RAM
- MicroSD Slot
- 16GB eMMC Flash
- eDP LCD display
- HDMI
- USB Host
- Battery management
- 5V DC power supply
- Certified Open Source Hardware (OSHW)
Works:
- i2C
- MMC/SD
- PWM backlight
Known broken:
- Internal keyboard (seems to be because the keyboard firmware loads a
bootloader first, and then disconnects bootloader and connect real
keyboard). External ones connected to the USB port work fine.
This patch enables support for the A64-Teres-I board to u-boot,
including enabling screen backlight (lacking from Linux device-tree).
Linux commit details about the sun50i-a64-teres-i.dts sync:
"arm64: dts: allwinner: a64: Rename uart0_pins_a label to uart0_pb_pins"
(sha1: d91ebb95b96c8840932dc3a10c9f243712555467)
Cosmetic warnings regarding whitespace and placement of SPDX notice for
dts file was ignored.
config and .dtsi file are adapted from pinebook files.
Tested-by: Jonas Smedegaard <dr@jones.dk>
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
[jagan: move board entry in MAINTAINERS file at proper position]
