path: root/configs/teres_i_defconfig
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-15sunxi: move CONFIG_SPL_TEXT_BASE from *_defconfig to KconfigAndre Przywara
The choice of the SPL_TEXT_BASE is not really a decision that should be specified by each board's defconfig, as this setting is actually dictated by the SoC's memory map and the BootROM behaviour. To make this obvious and reduce the clutter in the defconfig files, let's specify the SoC constraints in the Kconfig stanza. This allows us to remove these lines from the defconfig files again. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-05-20sun50i: a64: teres_i: Fix broken SPL_TEXT_BASEJonas Smedegaard
SPL_TEXT_BASE was moved into Kconfig, which previously part of include/configs before this teres_i support gets merged. Fix it by explicitly define in defconfig like other boards does. Signed-off-by: Jonas Smedegaard <dr@jones.dk> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-05-09sun50i: a64: Add Olimex A64-Teres-I board initial supportJonas Smedegaard
Olimex A64-Teres-I board is a mainboard (the only one so far) for Olimex Teres-I DIY laptop kit. Key features: - Allwinner A64 Cortex-A53 - Mali-400MP2 GPU - AXP803 PMIC - 2GB DDR3 RAM - MicroSD Slot - 16GB eMMC Flash - eDP LCD display - HDMI - USB Host - Battery management - 5V DC power supply - Certified Open Source Hardware (OSHW) Works: - i2C - MMC/SD - PWM backlight Known broken: - Internal keyboard (seems to be because the keyboard firmware loads a bootloader first, and then disconnects bootloader and connect real keyboard). External ones connected to the USB port work fine. This patch enables support for the A64-Teres-I board to u-boot, including enabling screen backlight (lacking from Linux device-tree). Linux commit details about the sun50i-a64-teres-i.dts sync: "arm64: dts: allwinner: a64: Rename uart0_pins_a label to uart0_pb_pins" (sha1: d91ebb95b96c8840932dc3a10c9f243712555467) Cosmetic warnings regarding whitespace and placement of SPDX notice for dts file was ignored. config and .dtsi file are adapted from pinebook files. Tested-by: Jonas Smedegaard <dr@jones.dk> Signed-off-by: Jonas Smedegaard <dr@jones.dk> Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> [jagan: move board entry in MAINTAINERS file at proper position] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
