CONFIG_IMX_VIDEO_SKIP
CONFIG_IMX_HDMI
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
Now that all the old code is gone, rename this option. Driver model
migration is now complete.
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20221024
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/13916
- for 2022.01
- rework Kontron boards (mx6 and mx8)
- fixes for Toradex
- fixes (SPI, CAAM, )
- sync DT with Linux
- fixes for Gateworks GW7903 and GW7904 PMIC
- Engicam i.Core MX8M Plus EDIMM2.2
... to avoid loosing characters when pasting text into the serial console.
This allows to remove the workaround to disable the vidconsole output
when no HDMI device is detected. This workaround only was there to speed-up
serial console processing.
Signed-off-by: Soeren Moch <smoch@web.de>
Reviewed-by: Fabio Estevam <festevam@denx.de>
CONFIG_PCI_SCAN_SHOW
CONFIG_PCIE_IMX
CONFIG_LBA48
CONFIG_SYS_64BIT_LBA
CONFIG_SYS_PBSIZE
CONFIG_SYS_MAXARGS
Add a 'bootdev' command to handle listing and selection of bootdevs.
Disable standard boot for a few boards which otherwise run out of space.
Conversion to DM_SERIAL is mandatory.
Select DM_SERIAL and add a imx6q-tbs2910-u-boot.dtsi file
that describes the nodes that require dm-pre-reloc, which allows
the DM model to configure the UART pinctrl early.
Remove the now unneeded board UART initialization.
Signed-off-by: Fabio Estevam <festevam@denx.de>
Tested-by: Soeren Moch <smoch@web.de>
CONFIG_BOARD_SIZE_LIMIT
To do this, introduce CONFIG_HAS_BOARD_SIZE_LIMIT.
This saves about 12 kBytes image size and helps to stay within the
size limit.
Suggested-by: Tom Rini <trini@konsulko.com>
Enable this for boards with a display, unless they are using the SPLASH
feature.
This shows a U-Boot logo on boards with a display, which seems like a
useful thing.
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Done via moveconfig.py
Done with:
./tools/moveconfig.py VIDEO_BMP_RLE8
This is not required for sysboot (we defined fdtfile), let's save a few
bytes in the binary image without these variables.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
We have a number of platforms that are a combination of a carrier board
and System-on-Module (SoM) that in turn allows for the board to have
different SoCs on it. In some cases, this is handled via board-specific
Kconfig options. In other cases we make use of
CONFIG_SYS_EXTRA_OPTIONS. This latter case however can lead to invalid
configurations as we will not in turn get options that in Kconfig are
selected by or depend on that setting.
To resolve this, make the SoC option a choice in Kconfig and make boards
depend on what they can support. This change opens us up for further
clean-ups in the cases where a single CONFIG_TARGET_xxx can support
different SoCs and today they do not, or do not cleanly do so.
Reported-by: Matt Porter <mporter@konsulko.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: "NXP i.MX U-Boot Team" <uboot-imx@nxp.com>
Cc: Soeren Moch <smoch@web.de>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Cc: Igor Opaniuk <igor.opaniuk@toradex.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Andreas Geisreiter <ageisreiter@dh-electronics.de>
Cc: Ludwig Zenz <lzenz@dh-electronics.de>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Akshay Bhat <akshaybhat@timesys.com>
Cc: Ken Lin <Ken.Lin@advantech.com.tw>
Cc: Ian Ray <ian.ray@ge.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
Cc: Simone CIANNI <simone.cianni@bticino.it>
Cc: Adam Ford <aford173@gmail.com>
Cc: Marcin Niestroj <m.niestroj@grinn-global.com>
Cc: "Eric Bénard" <eric@eukrea.com>
Cc: Baruch Siach <baruch@tkos.co.il>
Cc: Jason Liu <jason.hui.liu@nxp.com>
Cc: Ye Li <ye.li@nxp.com>
Cc: Eric Nelson <eric@nelint.com>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Parthiban Nallathambi <parthiban@linumiz.com>
Cc: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Niel Fourie <lusus@denx.de>
Cc: Martyn Welch <martyn.welch@collabora.com>
Cc: Richard Hu <richard.hu@technexion.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Boris Brezillon <bbrezillon@kernel.org>
Cc: Arkadiusz Karas <arkadiusz.karas@somlabs.com>
Cc: Breno Lima <breno.lima@nxp.com>
Cc: Francesco Montefoschi <francesco.montefoschi@udoo.org>
Cc: Silvio Fricke <open-source@softing.de>
Tested-by: Matt Porter <mporter@konsulko.com> [colibri_imx6]
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
Migration to DM_VIDEO changed the output device name (in stout, stderr)
from 'vga' to 'vidconsole'. This also was adapted in the default environment.
However, existing user defined environments still use 'vga'. Enable this
workaround to map the 'vga' name to 'vidconsole'. So we get HDMI video
output also with existing legacy environments.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_MXC_UART
Acked-by: Peng Fan <peng.fan@nxp.com>
This board is very close to its limit. Drop this command before the bd
refactoring, which increases the size slightly on one toolchain.
Migration to DM_VIDEO driver is long overdue, configure it in
board config files. To enable the display set stdout like:
setenv stdout serial,vidconsole
This keeps the compatibility with the old bootcmd.
The fdtfile environment variable also needed to be set to
imx6q-tbs2910.dtb to enable booting mainline kernels
otherwise with extlinux.conf it tries to load
mx6-tbs2910.dtb instead.
With arm-linux-gnueabi-gcc 9.2.0-1 from the Parabola
GNU/Linux distribution, we have the following size
differences:
- text: +2041 bytes
- data: 0 bytes
- bss: 0 bytes
- total: +2041 bytes
Signed-off-by: Denis 'GNUtoo' Carikli <GNUtoo@cyberdimension.org>
Reviewed-by: Soeren Moch <smoch@web.de>
This is needed to enable distro_boot support later on.
Adding the necessary configuration to enable booting general
purpose distributions is typically done by enabling
CONFIG_DISTRO_DEFAULTS.
However the resulting image size is is already very close to
the size limit and PXE isn't strictly needed, so instead we
made sure that all the configuration selected by
CONFIG_DISTRO_DEFAULTS were selected, with the exception of
PXE related configuration (CONFIG_BOOTP_PXE and
CONFIG_CMD_PXE) that are both disabled.
With arm-linux-gnueabi-gcc 9.3.0-1 from the Parabola
differences:
- text: +7526 bytes
- data: +28 bytes
- bss: -12 bytes
- total: +7542 bytes
This doesn't affect the size of the image: with
arm-linux-gnueabi-gcc 9.2.0-1 from the Parabola GNU/Linux
distribution, the text, data, bss and total sizes remain
unchanged.
As that the resulting image is already very close to the
size limit, and that CONFIG_GZIP is not strictly required,
removing it shouldn't hurt.
GNU/Linux distribution we have the following size
reduction:
- text: 9752
- data: 0
- bss: 16
- total: 9768
Acked-by: Soeren Moch <smoch@web.de>
The loadb and loads commands are not needed for booting.
There are also more reliable and faster alternatives to
loadb and loads that can be used with the current configuration.
size limit, removing the loadb and loads commands shouldn't
hurt.
reduction:
- text: 6733 bytes
- data: 116 bytes
- bss: 1172 bytes
- total: 8021 bytes
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
This shrinks the image size: all -3840.0 text -3840.0
